| Home | Forums | Gallery | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| Tuning: Electronic Engine Management Engine management electronics are the topic of discussion, be it an ECU re-programming, a replacement standalone solution, or a piggyback computer. Eg. Autronic, S-AFC, TEC-3, Unichip, UTec, etc. |
| Advertise On ClubWRX | |
| Welcome to the ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums. | ||
Thread Tools | Rate Thread | Display Modes |
#1 |
Cobbs AP economy map?????
So using AccessTuner i opened up two maps.
1. 91 octane stage 2 2. Economy mode for 91 octane stock injectors I looked at Fuel tables and Primary Ignition tables and im not impressed. This map does not seem to really offer any gains. Between loads of .58 and 1.44 (which you would usually be in daily driving and not pushing hard aka trying to get good MPG) fuel tables are the same (until 5kRPM+). Depending on where your at in the load columns, ignition advance is between ~4 degrees advanced in a very few spots, the same in most, and less in others. I tested these two maps out on an hour long fairly flat highway trip on Thursday night. With cobbs economy map i saw ZERO difference in MPG. I was cruising at 75mph @ ~2800 RPM. Ambient temps 50 degrees F. My question is where is their claimed gain in efficiency coming from? EDIT: i used 92 octane gas (no ethanol) just to make sure both maps were easily able to run to their full potential. |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cannot import maps in AP map manager | mr. jones | Tuning: Electronic Engine Management | 4 | 02-03-2007 10:30 AM |
| AP sti map for upgraded 2.5 | Sinister | Tuning: Electronic Engine Management | 2 | 01-28-2007 06:37 PM |
| AccessPORT 91 Oct Economy Map | tubbytreats | Engine Modifications | 6 | 08-06-2004 11:29 AM |
| AP Economy? | MomoWRX | Tuning: Electronic Engine Management | 16 | 08-06-2004 09:05 AM |
| AP map advice | AsianWRX | Tuning: Electronic Engine Management | 2 | 05-04-2004 12:14 PM |
