Results 1 to 7 of 7
This is a discussion on AP question within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; i just installed my AP and selected the stage 2 preloaded map it says i should be hitting 16.5 psi ...
    Registered User WRXwagonMAFIA's Avatar
    Aug 2008
    some old backroad
    AP question
    it says i should be hitting 16.5 psi boost, but im only hitt 11.9
    help???
    04' WRB wagon stage 2
    wagon Mafia #1 Where my wagons at?
    Aug 2008
    some old backroad
    i have TBE catless up pipe big TMIC cobb SF intake
    it says i may have to adjust the restrictor pill on boost control from the factory. what do all u scoobies recomend? past experience??
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Quote Originally Posted by WRXwagonMAFIA View Post
    I believe Cobb recommends the stock IC for the off the shelf map. Not sure about the pill - I think you leave it as is.
    11.9 - what gear is this in? 16.5 +- .05 is the absolute max you might see in 4th or 5th.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Aug 2008
    some old backroad
    thats through the gears . boost reading by the AP itself
    Aug 2008
    some old backroad
    what are all your feelings on the cobb ap map for stage 2 "use at your own risk" for people not hitting target booost
    Aug 2008
    some old backroad
    plzzzz help
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    i believe anything older than 06 can take up to 200 miles for the ECU to fully adjust to the new set up.
    even with my 06 / cobb OTS stage 2 map, im not hitting 16.x PSI consistently.
    you definitely should not be getting 11 though... (unless youre possibly in first gear)
    ALSO, i would not go by the AP boost reading, as i've found it to not be very accurate. if you dont have a boost gauge, i would invest in one.
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
