ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Tuning: Electronic Engine Management
Tuning: Electronic Engine Management Engine management electronics are the topic of discussion, be it an ECU re-programming, a replacement standalone solution, or a piggyback computer. Eg. Autronic, S-AFC, TEC-3, Unichip, UTec, etc.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 08-27-2008, 07:25 PM   #1 (permalink)
WRX_Karl's Avatar
Help!!
i was trying to update my firmware and as it was updating it said error or some **** and now everytime i plug in my AP to my car or computer all it says is updating...i cant get it to the main menu or anything
any suggestions?
WRX_Karl is offline   Reply With Quote
Old 08-28-2008, 12:13 PM   #2 (permalink)
Connect the AccessPORT to your PC and start the AccessPORT Updater program.
When it comes up with the window telling you to connect the AccessPORT to the computer, hit cancel. Then hit Update on the main updater window.
The Hide Details button will report that it is failing to connect to the AccessPORT over and over again. Just give it some time. Eventually it should connect.
After it connects, let it run through the updating process. If you encounter another error, navigate to the AccessPORT Updater installation folder (default: C:/Program Files/AccessPORT/AccessPORT Updater/) and make a copy of the "log.txt" file on your desktop. You can email this file to me at shayne@cobbtuning.com and I will do my best to have the problem diagnosed for you.
Shayne @ COBB is offline   Reply With Quote
Old 08-28-2008, 01:59 PM   #3 (permalink)
WRX_Karl's Avatar
thank you i got it to work and updated was a success!
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
