| Home | Forums | Photo Gallery | Groups (NEW!) | Advertise |
| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Tuning: Electronic Engine Management Engine management electronics are the topic of discussion, be it an ECU re-programming, a replacement standalone solution, or a piggyback computer. Eg. Autronic, S-AFC, TEC-3, Unichip, UTec, etc. |
| Advertise On ClubWRX | |
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
so i ordered the accessport for my 06 wrx and i began installation. i poked under the drivers side dash to connect the green test mode switch and found out it has already been connected. so i proceeded anyways and the screen tells me to plug in the test switch before it can load my map.. what the hell am i doing wrong
#2 (permalink) |
Grab a flashlight and crawl underneath your dash. Your car can't run if the test leads are connected. Double check...
__________________
06 GTO M6 Quicksilver 455 Bobcat 07 WRX TR M5 Garnet Red Pearl - Stage: I've given up on "stages". I spent way too much cash and my car's running fine (dyno'd 315whp/334wtq). I'm stage "hiding my receipts from the wife..."
#4 (permalink) |
When there connected your car goes thru a series of tests. most noticeable is the radiator fans running thru a cycle.
Well, try disconnecting the leads, reattach the AP, and then follow the onscreen directions. Call Cobb if u can't get it to work.
__________________
| Bookmarks |
| Tags |
| 2006 wrx, accessport, cobb, test mode, troubleshoot |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| AccessPort 2.0: Rock On, Except For One Quirk | slimasian | Tuning: Electronic Engine Management | 2 | 02-26-2007 02:20 PM |
| READ FIRST: AccessPORT Overview, Authorized Tuners and FAQ | WRC_Obsessed | Tuning: Electronic Engine Management | 3 | 08-14-2005 06:40 AM |
| Question about 2004 WRX | KnightWRXRider | Everyday Impreza Talk | 24 | 02-11-2004 03:52 PM |
