| Home | Forums | Photo Gallery | Groups (NEW!) | Advertise |
| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Tuning: Electronic Engine Management Engine management electronics are the topic of discussion, be it an ECU re-programming, a replacement standalone solution, or a piggyback computer. Eg. Autronic, S-AFC, TEC-3, Unichip, UTec, etc. |
| Advertise On ClubWRX | |
LinkBack | Thread Tools | Rate Thread | Display Modes |
#2 (permalink) |
If you have AP V1 you donot have this ability.If you have AP V2,you obviously have not read the instructions yet.
__________________
Aarrg matey!!Ecu pirated by RomRaider! My Mods ![]() My Pics http://www.cobbtuning.com/info/?ID=3223 http://www.spdusa.com/blow-off_valves.htm |
#3 (permalink) |
The dyno feature isn't working right (for me either). Be patient and they (Cobb) will have an update out soon to fix it. The 1/4 miles feature works but is not accurate. Go to your local dragstrip for real results (and safety).
__________________
06 GTO M6 Quicksilver 455 Bobcat 07 WRX TR M5 Garnet Red Pearl - Stage: I've given up on "stages". I spent way too much cash and my car's running fine (dyno'd 315whp/334wtq). I'm stage "hiding my receipts from the wife..."
#4 (permalink) | |
Quote:
The 0-60 time should be pretty accurate. I mean, the ECU knows the vehicle speed and the AP can keep track of elapsed time.
__________________
"Blondes not bombs....brunettes not fighter jets" Stg 2 Wagon Bugeye Mafia #152 |
#5 (permalink) |
i was told it was a v2 from the guy i bought it from and im pretty sure it is (its in color dont only the v2s have that?)
second i have read the instuctions but i dont see it saying HOW to do it anywhere, i do not mean to sound rude but if you are just going to give smart answers please do not waste either of our time, it would be twice as easy and very appreciated if you could just give me an answer. thanks and for the guy who said his dyno feature is not working proper, where even is the dyno feature? i have been looking through everything and cant find it |
#6 (permalink) |
Does it look like this?
![]() Then it's a New AccessPORT (v2). When you first start it up, it should say "live data" on the screen. If you scroll up to the next option it should be performance or something like that, I can't exactly remember as I'm not in my car, it's in there. Just turn it on and play around with it. Scroll through and explore in all the menus, then your AP will have no secrets from you.
__________________
#7 (permalink) |
I'm running 1.2.6.7 (latest version? Maybe I don't have the numbers right. I downloaded it last week).
Dyno didn't work for me. The 0-60 and 1/4 did, just don't know if I trust it. Ease up on the new guy. The AP is not easy to newcomers.
__________________
#8 (permalink) |
yea it does look like the one in the picture im not sure what it says right when i turn it on but ill check next time. Im currently stg 1 (just waiting on my dp and up to go stg 2) but if the map is flashed or w/e does that mean it is on my car no matter what even if i unplug the AP? because i dont really like that wire hanging down while i drive lol
and im not sure about the times either, but then again im not launching my car AT ALL, bit off subject but does anyone know a good way to launch without dumping the clutch lol. |
#10 (permalink) | |
Quote:
CobbTuning.com - Subaru Firmware: 1.2.8 There are two ways to apply a map to your ECU; your base map and a real time map. Your base map is flashed to the ECU and will remain until the ECU is flashed again. You can unplug the AP and disconnect the batter (cutting power to the ECU) and your base map will remain. Your base map should be the one that matches your mods, i.e. you shouldn't have the valet map as your base map and stage 2 as your real time map, if you are stage 2. A real time map can be applied over the base map and is erased when the battery is disconnected. You don't need the AP plugged in unless you are monitoring data.
__________________
"Blondes not bombs....brunettes not fighter jets" Stg 2 Wagon Bugeye Mafia #152 Last edited by DUB; 08-23-2008 at 10:28 PM. |
#12 (permalink) |
Slip the clutch.Launch Control helps too but Cobb only has that for the 2.5L WRX's and STi right now (retarded).Since I use Opensource software I have patched in Launch Control into the stock ECU programing thanks to Tiny Wrex's handywork.
__________________
#13 (permalink) |
great, thanks for all the answers im pretty sure its that i havent updated the firmware or whatever yet then because i dont even SEE the feature, much less know if its even working right.
and i dont think he was telling you to ease up DUB i think he was talkin to donkey ha thanks everyone |
#14 (permalink) |
Sammich Makin Pwincess #1
definitely update your firmware. once you plug in the AP you should be able to scroll through the settings
go to: dynometer. then you'll have 3 options: 1/4time. 0-60time. hp.tq once you select the hp/tq, it'll ask you to select the weight of your car, select a gear, and the RPM range you want. you'll have to experiment in order to figure out the perfect test gear/rpm range though. its a little tricky to actually get it to work properly though... lets say you set it for 3rd gear/ 2k-6k rpms. you have to keep the car under 2k rpms in 3rd gear, and let it sit for a bit to register into the AP. then it will tell you to floor it. sorry im kind of rambling. but yeah. when i did the test, it told me i had 179 hp.... yeahno.
__________________
your friendly, neighborhood subaru girl =) 06 wrx impreza: cobb stage II! // myspace; a place for friends hawk-eye alliance #1111 // wingl3ss @ll!ance #17 |
| Bookmarks |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 06 STI less Hp + Tq than 04/05 | WRXcelration | Engine Modifications | 24 | 11-30-2006 09:45 PM |
| stock block STI 440 TQ / 447 HP | Quantum-Racing.com | STi Engine Performance | 16 | 01-01-2005 01:54 PM |
| Tuned my car. 536 hp/ 470 tq, video and chart | STEALTH-WRX | Engine Modifications | 42 | 11-18-2004 11:34 AM |
| Dyno: 221 hp/ 195 tq - Basic bolt-on's | jarelee | Engine Modifications | 11 | 02-12-2004 01:48 PM |
| m2 or mrt turbo back exhaust | showcasewrx | Engine Modifications | 29 | 10-29-2003 02:56 PM |
