ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Tuning: Electronic Engine Management
Tuning: Electronic Engine Management Engine management electronics are the topic of discussion, be it an ECU re-programming, a replacement standalone solution, or a piggyback computer. Eg. Autronic, S-AFC, TEC-3, Unichip, UTec, etc.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 05-08-2008, 12:28 PM   #1 (permalink)
"Supreme Subaphile Extraordinairre"
Supporting Member
ninefourteener's Avatar
Yes, you need an EM for engine mods
I've noticed quite a few questions regading the necessity of an Engine Management system (EM), based upon certain upgrades. Rather than searching in 27 different threads to find out, I'm going to try to create an all-inclusive thread.
With that, I'm going to (hopefully) clear up any misconceptions...
1) A catback exhaust (CBE) does almost nothing for your car except make it sound cooler.... you do not need an EM
2) An aftermarket intake "can" cause your car to run lean (too much air, not enough fuel)... so yes, you should be tuned. The exception would be an SPT intake, as Subaru claims they are safe to run on the stock engine/ECU. However, I would get tuned anyway.
3) A Turboback exhaust (TBE) includes a bellmouth Downpipe (DP). The DP allows your turbo to boost higher, and produce more power. With that, if your ECU is not telling your injectors to supply more fuel, and adjust the timing, to compensate for the added boost.... then once again, lean conditions and boost spiking occur. Yes, you need an EM.... period
*** Note, if you have a downpipe with no EM, don't complain when you blow something up.
4) An aftermarket top-mount intercooler (TMIC) with do very little for your performance... it will however, give you greater protection from heatsoak. No, you do not need a tune.
5) An aftermarket front-mount intercooler (FMIC) gives you added protection from heatsoak, but because the forced air has so much further to travel, it has been known to cause a bit of added turbo lag. The general rule of conscensus is that you don't need one unless you are over 350 whp. If you choose to use one anyway, then yes, you should be tuned.
5) a BOV will do NOTHING for you.. at all. In fact, if you don't get a recirculating BOV, you'll probably end up hurting your performance. Either way, you do not need a tune to install one.
6) On pre-06 WRXs, an aftermarket catless uppipe will give you added performance, and in many folks' eyes, is necessary preventative maintenance to ensure the catalytic converter doesn't get sucked up into the turbo. It will allow your turbo to spool up quicker, but generally will not cause lean conditions or boost spiking. For an uppipe only, no, you do not need a tune.
7) lightweight pulleys are the equivilent of removing weight from your car, you do not need a tune.
8) Turbo upgrades..... whatever it is, yes, you need to be tuned.... I can't tell you how many stock WRXs I've seen that bolt on a VF39, an 18G or a 16G turbo and drive off without doing anything else...... then complain about why their car doesn't run right.
Please... if you have anything else to add.... please do. Just seems like we get a lot of the same questions over and over again.... trying to help here and steer people in the right direction.
An EM should be the VERY FIRST item you buy for your car.... and I think just about everyone will agree with me on that one. Yes, they are expensive... but you only have to buy it once, it's infinately upgradeable, and most importantly, it's SAFE.
Hope this helps.
__________________
2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(Bordeaux Pearl)
WRX 12 sec drag (vs. late model Camaro SS): http://www.youtube.com/watch?v=lw0vWdD2cjU
WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=Qe8xK5Md_J4
Co-Founder/Admin-www.slcsubaru.com
Last edited by Rogan; 04-23-2009 at 09:44 PM.. Reason: changing title to something less aggressive
ninefourteener is offline   Reply With Quote
Old 05-08-2008, 01:20 PM   #2 (permalink)
Timdog1650's Avatar
Send a message via AIM to Timdog1650
If you edit the first paragraph to be a bit more user friendly and less abrasive, I think this would be worthy of being stickied...
Things I would include
Exhaust manifold/header: No, you do not need EM but you will realize better performance gains if you are custom tuned to account for this mod
Turbo Port/Polish:
No, not necessary. This, much like a catless uppipe, will simply increase the efficiency of the system, not necessarily a huge increase in performance. While this mod will certainly change the dynamics of your turbo system, it will not be outside the safe control of the stock ECU.
TGV deletes:
Yes, you need EM to delete the inevitable CEL that will result from deleting your TGV's and you need some way to tune for the increased airflow across the RPM range
Boost controller, manual or otherwise:
Yes, kind of. Any time you raise boost more than 2 psi on an otherwise mostly stock car, you should add engine management. The argument could be made that 2 psi increase or less is not going to do a whole lot to hurt you. That being said, you should not be increasing boost without aftermarket exhaust, and you should not have aftermarket exhaust without EM, therefore by the transitive property, you should not have a boost controller without EM.
Turbo inlet hose/any pressurized post-turbo piping or hoses: Absolutely not, these do very little to change the performance of the car and really only help making the turbo parts easier to remove/install.
Walbro Fuel pump: No, your fuel pressure regulator prevents a higher volume pump from overpowering the injectors and thereby altering fueling. If you change your fuel pressure regulator in any way, you will need to account for that change via tuning, but an otherwise drop-in Walbro replacement does not need EM.
Larger than stock injectors: Yes, you definitely need to tune for larger than stock injectors. A car will start with over-sized injectors and will likely drive "okay" but will not run properly and will be way too rich to drive aggressively.
Fuel Rails: No. See discussion of Walbro pump. More potential flow to the injectors does not necessarily mean your injector will inject more fuel unless you tell it to. Very minor tweaks may be needed if you do this mod, so minor you would probably never notice them and they would do no damage.
AccessPort vs OpenECU/RomRaider/Enginuity/Tactrix: Yes, AP is the easiest and most reliable way to modify your stock computer. The "DIY reflashes" are also very good and much cheaper. If you think you are going to need engine management, do not immediately discredit the DIY methods. With proper education, patience, and a careful and inquisitive mind, flashing a stage 2 car yourself is reasonably safe and easy to do. Making the choice to do it yourself is basically a measure of how confident you are that you can follow carefully outlined procedures and use good common sense to troubleshoot a problem if something goes wrong. The Cobb AP is basically idiot proof, but you have to pay for this feature, as well as their customer support.
Timdog1650 is offline   Reply With Quote
Old 05-08-2008, 01:44 PM   #3 (permalink)
Supporting Member
Quote:
You're right... didn't mean to come across like that at all.
I changed it... I think it sounds more PC
__________________
Old 05-08-2008, 01:57 PM   #4 (permalink)
Timdog1650's Avatar
Good stuff, I'm gonna report this to the forum mods and see if they can throw it in the stickies.
Old 05-08-2008, 02:27 PM   #5 (permalink)
Scooby Hooligan
Weasel 555's Avatar
Send a message via AIM to Weasel 555
how about i put it in the Electronic Engine Management thread
plus i want to delete the AP port , its definitely not the most reliable
__________________
ScoobyDMC #000,HawkEyeAlliance#000,Blobeye Syndicate #000, SQC-NY #009, "Dragon Slayer"
"All We'll Drive"
Quote:
Originally Posted by Speedette
rub the syrup all over my bum
Weasel 555 is offline   Reply With Quote
Old 05-08-2008, 02:35 PM   #6 (permalink)
Timdog1650's Avatar
Quote:
That works, would it be too much to ask for both since they're inter-related?
I guess it's a matter of opinion, but it certainly does what it's intended to and has a solid track record. What would be your pick for "most reliable?"
Old 05-08-2008, 03:26 PM   #7 (permalink)
Micah's Avatar
Send a message via AIM to Micah
plus i want to delete the AP port , its definitely not the most economical
fixed?
__________________
Micah is offline   Reply With Quote
Old 05-08-2008, 06:08 PM   #8 (permalink)
Moderator - "Win Diesel"
Rogan's Avatar
Location: in the driver's seat, pushing the 'smoke' pedal
Send a message via AIM to Rogan Send a message via Yahoo to Rogan Send a message via Skype™ to Rogan
I'm actually working on a thread sticky/addition/whatever, offline, that will be posted up soon.
But yeah, I concur on the merge.
__________________
Rogan o_0
Never be afraid to try something new.
Remember, amateurs built the ark.
Professionals built the Titanic.
'96 Dodge 2500 CTD @ 40psi - 330whp/620lbft Tq - soon to be 350/700, dual-stacked, and 5speed!
http://www.rickwall.net
Rogan is offline   Reply With Quote
Old 05-08-2008, 07:04 PM   #9 (permalink)
tmann05's Avatar
sticky this biotch...ill be reading this often...of course when i do get an STI
__________________
Tyler - Aspen White 04' STI
Blobeye Syndicate #40
Stage 2 - 312HP ~ 339 lb ft. torque
Live Gamertag - TMANN05
NOTE: If you run a turbocharger beyond it’s compressor efficiency range, it will turn into a flame thrower.
tmann05 is offline   Reply With Quote
Old 05-10-2008, 11:34 AM   #10 (permalink)
Reincarnated Stalin of WRX tuning
Donkey's Avatar
Okay.You replace the stock tube and fin TMIC with a bar and plate TMIC of close to similar size.Now you have gone from a 2psi pressure drop to a .5 psi pressure drop.That means you are now overboosting by 1.5psi or maybe more depending on how the stock temp compensation can correct plus probabaly over running the stock load mapping.A tune would be a good idea for the same reasons as a TBE except now the pressure differential is on the intake side.Plus tuning for a more efficient TMIC allows you to run more boost and more timing advance with leaner AFR's.Also you have 2 #5's
__________________
My Mods My Pics
Donkey is offline   Reply With Quote
Old 05-12-2008, 01:17 PM   #11 (permalink)
Moderator
Moved over to EM for the time being as it seems more "fitting" in that forum.
Good info in here.
__________________
302@12psi is offline   Reply With Quote
Old 05-22-2008, 06:48 PM   #12 (permalink)
FlimFlamMan's Avatar
Good info.. and a quick read (not 5 miles long).
__________________
07 WRX
Stage 2
FlimFlamMan is offline   Reply With Quote
Old 05-26-2008, 06:19 PM   #13 (permalink)
Moderator
Silver Supporting Member
timber's Avatar
Send a message via AIM to timber Send a message via MSN to timber
I'll throw one out there, what with fuel prices being what they are..
Higher Than Recommended Octane Fuel: Don't waste your money on higher than recommended octane fuel, as your car cannot take advantage of it unless you are tuned for it.
__________________
"Never Launched"
Dougie
- Founder, 250,000 mile club
-5,000 posts
timber is offline   Reply With Quote
Old 06-29-2008, 02:57 PM   #14 (permalink)
05wrxftw!'s Avatar
Send a message via AIM to 05wrxftw!
lol it was kinda "mean" but screw that......
people need to know whats what. i tell people straight up what they should/should not get, do or buy.
lol. i say Cobb AP is hands down the best bang for the buck. IMHO
05wrxftw! is offline   Reply With Quote
Old 06-29-2008, 05:03 PM   #15 (permalink)
Rogan's Avatar
telling them what they should/shouldn't buy, is opinionated.
your and my opinions differ. you enjoy Cobb, and I prefer RomRaider.
90$ vs. 600$.
$600 buys me EMS and 510$ of other go-fast goodies.
Again, though, opinionated.
__________________
Rogan o_0
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
replace em or cover em palmerx141 Interior Mods 11 03-06-2004 10:10 AM
Can't Find 'em....Grind 'Em....... CTWRX Everyday Impreza Talk 1 11-01-2003 11:18 AM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
