Yes, you need an EM for engine mods - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 104
This is a discussion on Yes, you need an EM for engine mods within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I am looking into the Vi-pec V44 for my 97 WRX. One of the most praised features I can see ...
  1. #46
    Mar 2009
    I am looking into the Vi-pec V44 for my 97 WRX. One of the most praised features I can see in it, is it's Auto-tune ability.
    But in the manual, it states to run the auto-tune in a controlled scenario (eg Dyno) So the "Quick and simple user-friendly" Tuning method, still requires a $500 trip to the tuner, which is no easier then any other ECU.
    Am I correct in saying this? Or can this auto tune feature be used with all 4 wheels jacked up, or on a long abandoned road?
    Do all ECU's need a Dyno for a tune? I will be doing my WRX up progressively and think spending $500 for possible 3-4 tunes a bit much.
    Cheers.
  3. #47
    Moderator Donkey's Avatar
    Da boonies,Va
    I think the controlled scenario might be for legal and safety purposes.I "road tune" mine and my friends cars.Most dyno tunes clean up with some logging on the road.Find a nice stretch of road with out traffic and safely do some third gear pulls.The Vi-pec looks pretty impressive.It comes with datalogging software so that can be used to double check the tune.Most dyno shops will have a wideband AFR sensor to use for tuning so you might want to invest in one or there will be no way to know if your fueling is spot on.
    2002 FORESTER S
    1998 FORESTER S
  4. #48
    Registered User habitatxskate's Avatar
    Jun 2008
    hey i got something you can add to this post related to short ram intakes
    aps short ram
    All the intakes we sell have properly sized MAF housings that should NOT change your air/fuel readings. They all flow about the same; we observed five hp at the wheels using the Blitz SUS system on an otherwise stock 2.0 WRX.
    source: Short Ram Intakes - Intake
    i believe this also goes for the perrin and cobb short ram aswell..
    you may want to reword it to, anything with a different size maf housing other than the stock size will cause the car to run lean.
  6. #49
    May 2007
    behind the wheel
    Quote Originally Posted by habitatxskate View Post
    aps short ram
    {above text taken from fastwrx.com}
    key words: SHOULD NOT
    I've seen some do it anyway, because of the open air filament, but they're right, stock MAF housing diameter is the key.
    I DID, however, experience AFR differentiations in WHERE the MAF was located. In my CAI, simply moving my maf to a different location eliminated 99% of my stalling/stumbling issues, and smoothed out my AFR readings. Turbulence was the factor, I believe, in the changes in AFRs that I was seeing.
    Rogan o_0
  7. #50
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    Very wise words right there. Where did you find was the best place to mount the MAF?
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
  8. #51
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Just curious... Do I need EM?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  9. #52
    May 2007
    behind the wheel
    Quote Originally Posted by 20WRX04 View Post
    after moving it several times, it actually ended up being in a longer straight section, down by the CAI filter.. yes, i moved my MAF sensor down inside the fenderwell, just behind the bumper.
    Rogan o_0
  10. #53
    Nov 2004
    WNY
    Whatever works.
    NY GIANTS
    Hybrid Faction #19
    Mods
  11. #54
    Dec 2007
    AZ
    Quote Originally Posted by copternadle View Post
    I ordered the same borla exhaust too, and love the way it sounds it also looks very nice. I have people asking me all the time what kind of exhaust it is because it sounds so good. I got mine from borla parts here, borla 11760 and was pleased with the price a delivery time. You should also check craigslist sometimes you can find a used set.
    You seem to be having some problems with posting in the right thread, or you're purposely spamming
  12. #55
    Aug 2009
    Upstate NY
    Great thread, thanks!
  13. #56
    Registered User OliverJames's Avatar
    Jan 2010
    MA
    3) A Turboback exhaust (TBE) includes a bellmouth Downpipe (DP). The DP allows your turbo to boost higher, and produce more power. With that, if your ECU is not telling your injectors to supply more fuel, and adjust the timing, to compensate for the added boost.... then once again, lean conditions and boost
    So if I buy a TBE would I also need to buy a bellmouth DP with it? Is it the same with those cat downpipes and the catback exhausts? Or are they all interchangeable? As you can tell I know nothing about this stuff so please fill me in! Thank you
  14. #57
    [QUOTE=OliverJames][QUOTE]
    Resident Tuner @ WTF Tuning
  15. #58
    Jan 2010
    MA
    ohhhh thanks a bunch I get it now!
  16. #59
    Apr 2010
    Sacramento
    what is the difference between TBE and CBE?
  17. #60
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by Kamakazecam View Post
    See diagram above. The TBE (turbo-back exhaust) includes replacement of everything from the turbo back: downpipe, mid pipe and cat back sections. The CBE (cat-back exhaust) replaces only the cat back section, everything after the cat in the midpipe.
    Cody
