Utec
Results 1 to 7 of 7
This is a discussion on Utec within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I brought my WRX up from Texas (sea level) to Utah. It has quite a few mods and im curious ...
    Registered User bnels2348's Avatar
    Jun 2006
    Salt Lake City
    Utec
    I brought my WRX up from Texas (sea level) to Utah. It has quite a few mods and im curious if I should retune it for the higher elevation. (AFR and what not)
    Also what is a good range for the Timing #1 on my dashboard in the UTEC? right now its running about 12.7 degrees before TDC.
    Thanks for helping me out
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    I don't know the answer to any of those. But I would try posting over at Nasioc. There are a bunch of very knowledgeable people with UTEC godlike knowledge.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Registered User ktmrider's Avatar
    Sep 2006
    Albuquerque, NM
    A general rule of thumb on timing vs altitude is +2% for every 1000ft gain.
    I have used +10% for timing on my previous non-OBDII NA vehicles here in ABQ ( 5200ft ).
    On AF ratio, 14.7:1 is still the ideal target. The onboard O2 sensor and ECU will maintain this regardless of altitude. I don't recommend playing too much with AF, especially if you travel to lower altitude locations on a regular basis.
    Hopefully you have the selector switch with your UTEC, as with the AF if you travel to lower altitude you can cause some problems. Make a tune for your local area and have a backup for travel.
    2005 Legacy GT - stock for now
    1991 Galant VR4 - Sold
    2002 WRX Wagon - Sold
    Feb 2004
    Evansville, IN
    altitude doesn't affect turbo charged cars as much as NA cars since turbo charged cars are running an altered atmosphere anyways. Boost control will be affect more than anything. I be more worried about the difference in fuel quality than altitude.
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
    Sep 2006
    Albuquerque, NM
    Testes is right about the fuel quality. Higher altitude reduces detonation potential which is why we rarely find octane rating over 91 at "normal" filling stations. It is also the reason you can usually advance timing w/o having the ECU pull it out due to knock.
    Jun 2007
    Great Salt City of Utah
    Quote Originally Posted by testes1010 View Post
    The words of a master. I was having problems with my target boost after the weather got colder. I was over boosting and my KC was going nuts I changed the Waste Gate temprature compenstation and docked my WGDC durring spool and bam! I was hitting target boost once again. I thought I would have troubles with the KC still but every thing was strait. 4.5 across the board.
    I <3 enginuity.
    Jun 2007
    Quote Originally Posted by ktmrider View Post
    That is interesting You would think it would be opposite but I guess with less/thinner air, you don't have to worry about lean mixtures.
