Results 1 to 2 of 2
This is a discussion on can anyone help with DEFi gauges install ? within the Tri-State forums, part of the Regional Discussion category; can anyone help me out from around philly area or jersey . or anyone have an idea how much it ...
    Registered User ibobby di's Avatar
    Feb 2004
    New Jersey
    can anyone help me out from around philly area or jersey . or anyone have an idea how much it would run to get installed ? ( control unit , boost , oil pressure and egt )
    Registered User ButtDyno's Avatar
    Apr 2003
    Alexandria, VA
    Re: can anyone help with DEFi gauges install ?
    Oil pressure isn't that bad.. you just have to buy the galley plug, remove the IC, install the sender, run it through the firewall (near the pedals is easy) and run it to the gauges/unit. There are directions on scoobymods.
    For EGT you need to tap your exhaust manifold (if you are getting an aftermarket header, wait until you get that to do it) and then run the wires through.
    Never installed a boost gauge (my car came with one), not sure how bad that is.
    john
