Question on PA inspection of lights - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Question on PA inspection of lights within the Tri-State forums, part of the Regional Discussion category; alrighty...if you want to get technical/written about it....we'll take the time to disect this. f) Illumination except headlamps, fog lamps ...
    Registered User Roamin'Coyote's Avatar
    Aug 2002
    Chester County, PA
    f) Illumination except headlamps, fog lamps and auxiliary driving lamps. A vehicle specified under this subchapter shall be equipped with parking lamps, stop lamps, tail lamps, turn signal lamps and hazard warning lamps designed for that specific function, which under normal atmospheric conditions shall be capable of being seen and distinguished during nighttime operation at a distance of 500 feet. See 75 Pa.C.S. § 4303(b)—(d).
    (1) Stop lamps, turn signals and hazard warning lamps shall be visible at distance of 100 feet during normal sunlight.
    This part is most applicable to your question in the code that you provided. Reading just this part of the code would indicate that there are no provisions as to the color of the bulbs in turn indicators.
    However you fail to note a key passage before this one (175.66(b)):
    (b) Lighting standards. A lamp shall comply with vehicle lighting equipment requirements of this title. See Tables II—IV; Chapter 153 and 75 Pa.C.S. § 4301.
    From Chapter 153:
    § 153.1. Purpose and scope.
    This chapter specifies requirements for original and replacement lamps, reflective devices and associated equipment necessary for signaling and for the safe operation of motor vehicles during darkness and other conditions of reduced visibility.
    TABLE IV—LOCATION OF REQUIRED EQUIPMENT—Continued.
    ALL PASSENGER CARS AND MOTORCYCLES, AND MULTIPURPOSE PASSENGER VEHICLES, TRUCKS,
    TRAILERS AND BUSES OF LESS THAN 80 INCHES OVERALL WIDTH
    Turn signal lamps - Location on Passenger cars, multipurpose passenger vehicles, trucks, trailers and buses -
    At or near the front—1 amber on
    each side of the vertical centerline,
    at the same height, and as far apart
    as practicable.
    On the rear—1 red or amber on each
    side of the vertical centerline, at the
    same height, and as far apart as
    practicable
    I think that about settles it....sorry.
    http://www.pacode.com/secure/data/06...hap153toc.html
    gfx
    gfx is offline
    Registered User gfx's Avatar
    May 2003
    Pittsburgh, PA
    Ah, damnit. I'm just going to pick up some clear bulbs that flash amber then.
    2003 5MT WRB WRX Sedan
    Cobb stage 2.5 w/ VF30, Stoptech BBK, JDM STI front/rear seats, Mattjk LCD setup, JDM headlights w/ McColluch 6000k HIDs, GReddy EVO, 17x8" Gold Rota Torques, Eibach Pro-kit
    http://www.cardomain.com/id/gfxwrx
    My car shots taken with my Canon 300D dSLR
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    Originally posted by Roamin'Coyote
    isn't there a bulb that looks silver/blue/clear that blinks yellah? PIAA ion crystals? or something? I can't remember.
    Those are technically Sylvania Silverstar bulbs (Osram Diadem).
    Silver spray paint or chrome spray paint...
