Results 1 to 9 of 9
This is a discussion on NJ Emission question within the Tri-State forums, part of the Regional Discussion category; Anyone in NJ have the TurboXS Turbo Back Exhaust? I am curious if this setup passes emissions, since it removes ...
    Dec 2002
    NJ, USA
    I am curious if this setup passes emissions, since it removes all cats and just has one high flow cat.
    Thanks in advance.
    Registered User ManguWRX's Avatar
    Nov 2002
    Raleigh, NC
    Im curios about the emission. Do they Dyno test our Cars?
    I know is not done to SUV's cause they are AWD.
    Please let me know. Cause if thats the case they wont know you are missing the CAT's.
    Aspen White 2003 WRX
    COBB STG 2
    SQC #076
    Moderator beastcivic's Avatar
    Mar 2002
    Charlotte, NC (USA)
    They could still do an emissions test. Either they'll have you go to a place with an awd tester or they'll do it the way they used to... in neutral, and manually rev the car up to 1600 and 2500 rpm and do the test while not under load.
    -Jim
    '02 Platinum Silver WRX sedan w/roof rack...bone stock. Ok, now that's a lie.
    GO HOKIES!!!!!!!!!
    Dec 2002
    NJ, USA
    I guess my question should have been
    If they are able to test the car at the facility, will the car pass w/ the turbo back exhaust installed?
    Thanks
    Registered User Evil Imports's Avatar
    Oct 2002
    AZ
    i used to work doing NJ inspection
    anything that is AWD will just get a RPM test, (the just rev the car at 2k or so
    ANY muffler other then stock will fail (so if you have the turbo back, just put the stock axle back on to bring it to DMV)
    as long as they see you have 1 cat you will be ok, (as long as it passed the emissions test)
    anything else you wanna know i will answer the best i can
    Nov 2002
    Raleigh, NC
    Hey evil why wont the aftermarket exhaust wont pass?
    Air press?
    COBB STG 2
    SQC #076
    Dec 2002
    NJ, USA
    What about the local independent shops that do inspections in NJ. Will they be as stringent on the full exhaust setup?
    I was going in for an inspection to get it done so I have a full two years before I need inspection again, I'd just like to know if in your opinion I'd have a better shot at a local garage passing me than the state facility...
    Thanks
    Oct 2002
    AZ
    Air press?
    i donno really, they started that after i quit, my boy that still works there was telling me, its not with the whole exhaust only the muffler, the only reason why i can think that they started that was because we couldn't fail people for loud exhaust (like honda's and stuff) so i think they just made up the new rule about the muffler, but it always depends on where you go, some people are cool and some aren't
    Registered User InfamousDX's Avatar
    Jan 2003
    Bergen, NJ
    I was planning on getting the MRT Turboback exhaust because it retains at least a "high flow" catalytic converter. I wonder if it'll pass with the other 2 cats removed. With my old turbo Honda, I was running lean with a crappy high flow cat and I still failed the world.
