PA Emissions inspection and stage 2 cobb?
Results 1 to 12 of 12
This is a discussion on PA Emissions inspection and stage 2 cobb? within the Tri-State forums, part of the Regional Discussion category; does anybody in PA pass state inspection with cobb stage 2? If so how? Gotta "buy" a sticker or what? ...
    Registered User WRX-Rated's Avatar
    Dec 2002
    Whitehall, PA
    I want to go stage 2, but I need to know how to keep it on the road.
    04 platinum silver metallic WRX 4EAT, 04/05 STi coming soon as well.
    Nov 2005
    The Holy Commonwealth of Pennsylvania
    Quote Originally Posted by WRX-Rated View Post
    Yeah, all PA does is use the diagnostic port. There is no sniffer. If you don't have a CEL, you pass. The reflash suppresses it. AP=pass inspection. What county you looking to have it done? I know a great shop in Lower Bucks.
    Dec 2002
    Whitehall, PA
    Well, we live in the allentown area, not sure what county this is, or what inspection stations are close to us, but we have a little time left to go still. I just cant spend the $1,800 on the stage 2 package, unless It's going to keep the car street legal. If it does, then I would be very happy to purchase it in the spring so next summer can be a blast.
    Oct 2004
    Westchester Cnty, NY
    If PA ONLY uses OBD-II then you will pass as long as:
    1) AP is properly installed
    2) AP has cleared all codes - it should, just make sure the lights off
    3) You wait at least a month after flashing to get inspected because it takes a certain number of duty cycles for all of your sensors to be in the "ready" position. if they are not "ready" you will not pass. It is just a matter of time.
    2015 Plasma Green Pearl XV Crosstrek Hybrid Touring
    2011 Lightning Red WRX LTD Sedan w/ Nav (returned)
    2008 Lightning Red WRX Prem. Hatch w/ Nav (returned)
    2005 San Remo Red WRX Prem. Sedan w/ VF34 (traded)
    Mar 2005
    York, PA
    Don't spend $1800! just get an uppipe,downpipe, and catback then run open source ECU maps. Check out http://www.plasmatize.com/osecuroms/
    Buy a $90 OBDII --> USB cable and hook it up to a laptop and you can supress all of the CEL's you want. It takes a lot of reading and learning but I think the savings of $500 are worth it.
    Nov 2005
    There are probably a ton of them. You are in Lehigh County, BTW.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by D0WNxSH1FT View Post
    I also found it helpful to be up front with the shop doing the test. If you have an aftermarket cat, let them know.
    Mods & Pics
    Dec 2002
    Whitehall, PA
    The cobb stage 2 kit, will be ordered catless, I belive thats an option anyway. It looks like their downpipe can come with, or without cats. If I purchase the system from them catless, will PA inspection look under the car and fail me for catless? (I assume yes if they knew this setup was on the car?)
    Thanks so far for all the replies, much appreciated!
    Apr 2004
    Southeastern PA
    I have passed twice. The last shop I used was concerned with the aftermarket cat. I pointed them to Cobb's website and showed them what was installed. They semi-reluctantly passed it. I will be going elsewhere this year (soon, within the next 90 days).
    There is supposed to be no visual, but who knows? Removing a cat is verboten. Again, check with the shop and tell them what is going on underneath before committing to the test.
    Mods & Pics
    Nov 2005
    Yeah, the guy that did my inspection was I guy who I got baked/worked with at a Pizza Hut in high school with so I didn't have to really worry about it.
    Registered User copracer288's Avatar
    Nov 2002
    Lehigh Valley, PA
    I also live in Lehigh County. I have Cobb Stage 2 and am catless.
    As previously stated, as long as there are no trouble codes, the computer test will pass. I have a Godspeed DP which does not trigger any codes.
    As far as visual inspection goes, I'd be willing to bet most garages never look. If they do, though, it could be a hassle.
    I've used US Automotive (Hanover Ave, Allentown), Star Automotive (RTE 873, Neffs) and Peters (RTE 863, New Tripoli) and have had no problems.
    Rob
    '07 Dodge Charger SRT8, black
    Gone but not forgotten: '04 STi, '01 Camaro SS
    Life Member: Veterans of Foreign Wars
    Registered User tturbotom's Avatar
    Nov 2004
    AJEAutosports.com
    Emissions testing varies from county to county within PA. Some counties only do a visual, Luzerne County (where I am) does a visual and gas cap test, others do an OBDII scan and so on. And from "understand" you are exempt from emissions testing if you drive under 5000 miles a year.
    Tom ~ 06 WRX Wagon
