2011 wrx build thread 325awh at 351 torque
Results 1 to 2 of 2
This is a discussion on 2011 wrx build thread 325awh at 351 torque within the Tri-State forums, part of the Regional Discussion category; I just wanted to share my build off of my 2011 wrx. All of the work concerning the actual build ...
    Registered User Scooby_newbie's Avatar
    Feb 2012
    2011 wrx build thread 325awh at 351 torque STOCK turbo
    I just wanted to share my build off of my 2011 wrx. All of the work concerning the actual build has been done by IAG and i am more than happy with the outcome. IAG will be doing much more work for me in the very near future with my wrx.
    Build Reason:
    The reason for my build was ultimately do to a negative result of low oil in my wrx that yielded very bad results to say the least .
    Prior build history:
    Prior to this build i was a simple stage 2 car running Cobb stage 2 (catted downpipe by perrin, AEM CAI and a nameless axle-back muffler delete set-up)
    Quick recap of the "bad" moment:
    Driving down I81 during the first snow and the car shuts off next to an 18 wheeler forcing me to pull off and wait for 2 1/2 hours for a tow back to my house.
    The Build start history:
    I was debating on what to do with the car and where to take it to. After calling multiple shops and much debate on the expenses that would soon take place i went with IAG. I went with IAG after talking with Drew and Rick over the course of a few days. I felt much more at ease after dealing with Drew and Rick from IAG and i was sold. I had the car towed to IAG after it sitting in my garage for over a week. Over the course of a few weeks/ a month i had gotten funds together to start the initial process of diagnosing and taking things apart. I knew that they were extremely busy at the shop. I basically had the car towed and let the guys have at it. I called very very few times as Drew and Rick were quick to call me with updates and new findings. As time went on, my parts list grew and grew as i kept adding on goodies to ensure a strong foundation for a proper build for future modifications. These decisions were based off of the excellent help and direction help of Rick.
    Destruction findings:
    The car ran low on oil with no real warning signs. I ended up spinning a rod bearing in cyl 2 and cyl 2 piston had a ringland that simply fell apart upon inspection, the rod was obviously bad as well.
    The parts list for the build
    Top end:
    GSC Stage 1 cams
    Springs, retainers
    No actual head work as of right now other than the cams, springs and retainers
    Bottom End:
    Manley H Beam rods
    Manley pistons 99.75mm
    Cylinders obviously machined to fit the pistons
    (Race bearings)
    Heat treated crank
    Fueling:
    Walbo 255 pump
    ID 1000's
    Exhaust:
    Perrin Catted DP
    Nameless Axleback muff delete
    IAG Un-equal length headers
    IAG Up-pipe
    Perrin Turbo inlet
    Intake:
    AEM CAI
    Intercooler:
    Perrin TMIC
    Turbo:
    Stock turbo (for now)
    Tial 38mm EWG (external dump)
    Oiling system:
    Killer B Pick-up system
    Boost Control:
    Grimmspeed EBCS
    Odds and ends:
    Crawford Air/Oil separator
    Air pump delete
    All race bearings
    After having the car tuned at IAG the results were not what i had expected. I was expecting numbers from 280-MAYbe 300 being as i am on stock turbo.
    The numbers are as follows:
    324awhp at 351 torque (uncorrected)
    The car is very fun to drive! AND i am glad i went with a set of cams as they REALLY helped out a lot in reaching those numbers.
    My next mods are as follows:
    Bigger turbo and STI tranny swap. My next goal is to hopefully be around mid to high 400's with a bigger turbo (i was thinking the 3-xtr? open to suggestions)
    Feb 2012
    Transmission:
    ACT Heavy Duty modified street.
    Sent from my LGL55C using Tapatalk 2
