help!! 2011 wrx codes
Results 1 to 15 of 15
This is a discussion on help!! 2011 wrx codes within the Tri-State forums, part of the Regional Discussion category; so im on the highway and i was pushing it a little bit and went to shift into 5th and ...
    Registered User JGhost's Avatar
    May 2011
    middletown, ny
    Exclamation help!! 2011 wrx codes
    so im on the highway and i was pushing it a little bit and went to shift into 5th and my check engine light, traction control light, and cruise control light all went on..my friend told me what to do , i reset the codes..now he told me i should get a boost controller, but have no idea where to look or what to get, im still a noob with turbo cars, can someone help? thanx
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    What mods do you have?
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Oct 2011
    Fayetteville, New York, United States
    If resetting the ecu cleared the codes and lights I would say you are fine. You do not need a boost controller if the car is not heavily modified.
    If your friend told you to reset the codes without reading them first, he's a moron and should never be listened to again.
    Resident Tuner @ WTF Tuning
    Registered User 2.0Rs's Avatar
    Jul 2007
    King of Prussia, Pa
    You should have gotten the code pulled so you know what the issue is. Any other mods?
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    +1
    Why didn't you read the codes first to see what they were? What mods do you have done to it?
    Ignore anything your friend tells you, he clearly doesn't know what he's doing there.
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    May 2011
    middletown, ny
    my bad guys havent been on, i did read the code, he told me read the code and it was the wastegate i believe, i have a downpipe, catback exhaust and sf intake
    Quote Originally Posted by JGhost
    The overboost code mentions the wastegate.
    Next time it happens, make note of the P#### value.
    Jul 2007
    King of Prussia, Pa
    Why would you put these mods on without a tune? That's generally the code that pops up on untuned cars. tune it
    Apr 2007
    8000' up in Colorado
    What tune are you running to support your mods?
    Scott
    May 2011
    middletown, ny
    i didnt have it professionally tuned, im running the stage 2+sf on the cobb accessport
    Worrying at this point does nothing. You don't have the exact code, so no one can tell you what the issue was. If/when it happens again, make note of the P#### value as I said before. Otherwise, don't lose any sleep over it...
    May 2011
    middletown, ny
    im not worried about it, hasnt done it again. if it does ill be sure to get the exact code
    May 2011
    middletown, ny
    ok well the other day it happened again, P0244.wastegate solenoid A...is this overboost? its weird cause it only seems to happen when i punch it in 4th gear, im wondering if i should run the low wastegate map
    Jul 2007
    King of Prussia, Pa
    Why do you bother posting about this code when you aren't tuned? Get your car tuned then if you have a code pop maybe you have a legitimate issue. Or you can keep overboosting and break your engine. This guy had a new short block put in on an aftermarket warranty company. Went home threw on a turboback, intake and a boost solenoid. I can only imagine no tune. BOOM
