I run a 55 instead of the stock 45.Gives you a bit more height.
This is a discussion on Winter Set-Up within the Tri-State forums, part of the Regional Discussion category; Originally Posted by jgardiner Smaller diameter rims will not lower your car if you go with a higher profile tire. ...
2011 STi Build LogOriginally Posted by Trainrex
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
The Big 2011/2012 Mod Thread
Tire Rack has 17 and 18 inch wheels listed for the 2011 WRX, but if you select the Winter Tire/Wheel package, they recommend a 215/55R16, which has the same 25.3" diameter as the OEM 235/45R17's.
I think I'm going to try these 215/60R16's, though. 26.0" diameter (so 0.35" closer to fenderwell). I think with the narrower width, it might just fit.
http://www.tirerack.com/tires/tires....WS70&tab=Specs
You can post all your questions about winter tire sizes here & it will be answered by Luke from Tire Rack.
The Winter Tire thread- all winter tire questions go here !!! - NASIOC
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
