do you have a tune for your boost controller?
1) get rid of your catted uppipe asap & replace it w/ a catless one.
2) turboback exhaust
3) tune
First Modifications - what to do and not to do
Yes, you need an EM for engine mods
happy reading.
This is a discussion on 2002 wrx, dont know what to do within the Tri-State forums, part of the Regional Discussion category; i have a 2002 wrx, i have a cat back, cold air and a manual boost controller on it, i ...
i have a 2002 wrx, i have a cat back, cold air and a manual boost controller on it, i am wondering where i should go next for horsepower, i am looking for mods on the cheaper side.
3) tune
happy reading.
desiree
06 impreza wrx tr: cobb stage II - protuned by STi_Mikey!
hawk-eye alliance #11:11 // wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
You have a CAI - do you have a tune? If not, take it off now and wait until you can get a tune (might make sense to do at the same time as stage 2?)
The MBC - why do you have it? If it was on the suggestion of your tuner, go ahead - otherwise, why do you have it? It's not like it will make more boost for you.
First thing is to replace the uppipe and take off that CAI if it's not tuned. Then do stage2+cai+tune in the second step. From then, it makes much more sense to do things like brakes and suspension.
My big thread: The Used WRX Buying Checklist - Please Contribute!
My current car: 2002 WRB WRX Wagon.
Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
no my car is not tuned, i took off the mbc a week ago, it kept over boosting so i decided to take it off, and its really that bad to have a cai, i have an air to fuel mixture gauge and ts running ideal.
recommend a cobb acess port?
Some cai need a custom tune because they throw off your af ratio. Which one do you have?
The Ap is a good tool but it's not the best choice. A custom tune from someone in your area would be a better idea
desiree
sorry but cheap is not going to work. you dont have power mods for under $200. anyways...
1. CAI is for sound. your stock box can handle 300hp easy. buy an elbow delete or just remove the snorkel.
2. down-pipe and up-pipe replacement will cost you roughly $500-600 for cheap combo. i have a ERZ/CNT catted DP, and an invidia UP. $330+$140+about $50-100 in gaskets you'll spend.
3. these mods will require you to get a tune. road tunes range from $100-250 depending on tuner. protunes on a dyno will go $300+ although only places i know are like $400.
after that you are looking at $$. bigger turbo for the 2.0, along with injectors and intercooler... you can pump out 275-300hp at the wheels.
desiree
sorry. i should have not used the word required. i think i was tired. but the bugeyes can run untune but 1. you wont harness the power of the mods, so waste of money really 2. as wrxtreme said it is highly recommended as you are changing major flow characteristics of your turbo
thanks for all of the help guys, well now i am waiting to see if my car gets totaled or not because i hit a deer on a back road the other day.
The problem with a MBC is that with higher boost, all it takes is a bad tank of gas to ruin your motor and your day. It is best to leave the ECU in the loop so the knock sensors can do their thing and take out timing if it starts to detonate.
"If it ain't broke, fix it 'till it is"
cars getting fixed, going to buy an up and down pipe and then go get it tuned at a place called r/t tunning, any recommendations on a type of down/ up pipe or does it not matter?
