Need some kind of help on this. Hate new york emissions they are just about as bad as they were when i lived in cali. Anyone have an answer?!?
This is a discussion on New York State Emissions Testing!!!!!! within the Tri-State forums, part of the Regional Discussion category; Does anyone know what I'm going to need to pass ****ty new york emissions on my 2004 WRX it currently ...
Does anyone know what I'm going to need to pass ****ty new york emissions on my 2004 WRX it currently has an HKS catless up and down pipe. I bought the car from texas. Just need to know what the best catted downpipe is or if i should just have a cat welded to the downpipe? It currently is running a Forced Performance ported 16g turbo at 18psi. Need something that isn't going to cause turbo creep.
Look into an EWG setup (I plan to get the Grimmspeed one, because it has a bracket that holds the wastegate closed, and doesn't require you to weld the wastegate on your turbo). The HKS is not an ideal DP because of the flat-plate design (you may as well run a gutted stocker) which blocks the wastegate. This will cost about as much as a catted DP, but will give you more power.
If you don't want to go the route of EWG, I'd suggest getting a Bosal and a gutted stock 3rd cat. This will allow you to run catless, but still pass a visual inspection.
NY doesn't do a sniffer test, but it does require a visual inspection of the cats - a shop can lose its license by not doing the visual inspection. I would get a stock exhaust system and put it on the day of your inspection, then put the aftermarket one back on once you pass.
Just know that removing any factory cats is illegal, and you can be ticketed for it.
As I said before, the shop runs the risk of losing their license by not doing a visual inspectionOriginally Posted by wrx0131
Thanks for all the help. I think I'm just going to go with welding a cat to the mid pipe. Doesn't sound like a half bad idea. The only thing is this car is loud. And I know working in Ithaca there is a law that only allows 90dB which i'm sure this is much louder. lol all I need is to pass the inspection and avoid turbo creep.
Incidentally, an external waste gate (EWG) violates every emissions law known to man, the Geneva Conventions, and the Magna Carta. It is effectively a catless exhaust.
I'm not saying you won't get away with it, or that you will fail a test (the emissions from the EWG aren't sniffed, after all, since they don't exit at the tailpipe). I have no idea if an inspector with a keen eye will call the national guard on you. There's an easy way to find out though.
ha well that would be no fun to have to national guard called! lol I'm just going to weld a cat on to keep it semi-legal for new york state.
Sounds like a plan. You know, there are "shorty" pipe options that allow you to weld flanges on a cat, and swap the cat in for testing purposes. I follow all emissions laws in my state, but thought I would mention it so you know what options might be available to you.
Yeah it's alot of help. Where would i bolt that on tho?
Bosal Shorty Downpipe - Exhaust
for example.
Another thought is to buy somebody's used stock setup and have it handy. Takes little space up in the rafters somewhere and is less than an hour to bolt on when needed.
Alright makes a little bit more sense. Sorry I'm a little new to subaru's. The car before my WRX was a 2003 SVT Focus. A bit different from the boxer style WRX motor. Thanks for the help though. It's nice to know someone can always help out.
Yes, an EWG is illegal (though, he's running catless to begin with, so obviously this isn't an issue). I was simply throwing that option out because an exhaust like the catted Invidia would be similar in cost, yet the EWG will yield higher power (both in and of itself, and due to the wastegate being blocked by the HKS DP).Originally Posted by SD_GR
I would go this route. You can get them for $50-100.Originally Posted by SD_GR
To be fair, I remember in the 90s a German maker decided to use EWGs in their regular road cars and they went as far as putting cats on the EWG dump tube -- or so I read. In any case, the aftermarket EWGs don't go that far, and I'm now off topic.
