PA Law: Cats?
Results 1 to 8 of 8
This is a discussion on PA Law: Cats? within the Tri-State forums, part of the Regional Discussion category; I couldn't find an answer to this question so here it is: Which/how many cats do I need to have ...
    Vez
    Vez is offline
    Registered User Vez's Avatar
    Apr 2006
    Near Philly, PA
    PA Law: Cats?
    Which/how many cats do I need to have so I can -legally- pass a PA inspection?
    Is the number of cats actually important or do they just rely on the emissions results?
    Can someone please shed some light on this? Thanks.
    Hawk-Eye Alliance #081
    I'm the only person born a Pirate and trained as a Ninja; I sometimes don't get along with myself..
    2007 UGM WRX STI Ltd. #081/800
    Registered User Truckster27's Avatar
    Mar 2006
    Everywhere
    Need to have one cat per pipe...if you have dual pipes but they come to a common header (like a 4 cylinder with dual exhaust) you need only one prior to the pipe spliting to 2. Your passing is contingent on 2 tests: Visual and Emissions. Meaning that they need to be present, and they need to be "filtering" your nox and sox. Note that the visual fine in PA (meaning a cop pulls you over for excessive noise and looks under the vehicle) used to be in the nieghborhood of $1000 a pipe (Back in 1998)...It also depends on the freqency that your county requires emissions testing (example: In Baltimore MD its every 2 years, while Salisbury MD, which is 3 hours away, is never, only when you first purchase a vehicle).
    Movn' on up to an '06 WRX
    Vf-39 all the way!
    Love to build 'em, just to ship 'em out and start all over!
    I got friends in cyberspace, so I must be cool, right?
    Facebook / Myspace
    Registered User MarkF4E's Avatar
    Apr 2006
    Philly
    http://www.dep.state.pa.us/aq_apps/emissions/test.htm
    Depends from county to county, but its usually a visual check and an error code check. So I think your ok with 1 cat as long as its not throwing any codes.
    Wheel Painting Guide
    Bugeye Mafia Mbr #86 Takin it to da matresses.....
    Kennett Fire Company No. 1 Station 24
    Apr 2004
    Southeastern PA
    The dealer we bought our car from should give you no problems.
    Mods & Pics
    Registered User blackzwrx's Avatar
    Dec 2006
    Was Philly, now D-town
    All cats that were on the car from the factory have to be present to pass the visual inspection. That means that you can pass visual with dummy cats or high flow cats. That will get you through visual, since we(techs) don't look inside the pipes. Then the second part of the test is an OBDII ecu scan to check for DTC's. If none are present(even with no cats, thanks to some sort of EM) then you should pass. If you are having trouble getting through inspections, check my profile and shoot me a PM. I will be able to help you out.
    P.S. I'm an OBDII certified inspection mechanic, so listen to me, and me alone.
    '02 2.0l WRX, 237awhp, 236awtq. XPT Stage 2
    Bugeye Mafia #117
    Modders Anonymous #17
    Wingless Alliance #17
    Vez
    Vez is offline
    Apr 2006
    Near Philly, PA
    Thank you. Outstanding info.
    Cool Bill....thanks. They seemed cool, but I wasn't sure.
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Technically, you may not remove any cats that came on the car from the factory per Federal Law. Period.
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Quote Originally Posted by DUB View Post
    Laws were made to be broken.
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
