Results 1 to 7 of 7
This is a discussion on FS: (Philly) Whiteline 22mm adj rear swaybar. within the Tri-State Local For Sale Only ! forums, part of the Tri-State category; After doing some testing at an autox event last weekend I have decided to get a larger rear swaybar for ...
    May 2005
    Phillytown, PA
    After doing some testing at an autox event last weekend I have decided to get a larger rear swaybar for my car, so this one needs to go. This bar will make a nice upgrade over stock and allow for a similar size bar to be used up front to give you a very capable street setup.
    The bar has been on the car about a total of a month. I should have it off the car in about a week or so. I'm looking for $140 local pickup.
    Thanks for looking.
    May 2005
    Phillytown, PA
    Bump for me finally getting this off my car.
    Pics tomorrow.
    Registered User MarkF4E's Avatar
    Apr 2006
    Philly
    I may be interested and I'm going to the dogfish head meet. I'll let you know before then, but don't hold it for me.
    edit - I looked around but could not quite get the answer I was looking for. Will the stock endlinks hold up alright with this bar or do I need to upgrade? It will be seeing some autox but mostly backroad driving.
    Wheel Painting Guide
    Bugeye Mafia Mbr #86 Takin it to da matresses.....
    Kennett Fire Company No. 1 Station 24
    May 2005
    Phillytown, PA
    Quote Originally Posted by MarkF4E View Post
    The stock endlinks will work. They won't work quite as well as upgraded endlinks, but they'll get the job done. Even with the stock endlinks this bar would make an excellent upgrade when used with the stock bar or a an upgraded front bar.
    For AutoX use this bar will bump you out of the stock class FYI. Well, nevermind your other mods did that anyway.
    May 2005
    Phillytown, PA
    Bumparoo. Added pics.
    Apr 2006
    Philly
    Looks good man. Ill take it, Ill bring the cash to the Dogfish meet (if cash is fine with you).
    May 2005
    Phillytown, PA
    Cool. It's yours.
