Royal Purple Gear Oil going in - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
This is a discussion on Royal Purple Gear Oil going in within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; i have 1800 miles on my car, is it to earluy to change the trans fluid because i notice some ...
    Registered User br3ez's Avatar
    Apr 2004
    Bergen County, NJ / NEU, Boston
    i have 1800 miles on my car, is it to earluy to change the trans fluid because i notice some notchy shifting also.
    Registered User Retro's Avatar
    May 2002
    USA, FL
    Quote Originally Posted by br3ez
    I suggest you drive it some more to get more used to your car before you go changing the fluids, but if you do then I suggest trying a regular dino fluid. If it still feels notchy to you then I suggest that is the way it's supposed to be.
    clutch, shift, gas, clutch, shift, gas, shift, clutch, gas, clutch gas, shift... oops!
    Apr 2004
    thanks for the reply
  6. #19
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    I dont see why not. If it bothers you that much then go for it. Just remember like with any fluid the RP will get notchy and stiff eventually and as I have read, it needs to be replaced more frequently than stock. 15k intervals should be fine.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
  7. #20
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    I recently tried Valvoline fluid and I get a crunching sound when shifting into first almost every time. Worse than that OEM fluid.
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
  8. #21
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Quote Originally Posted by Anub1s
    I called the Subaru dealership and they said that Subaru's should never have Redline put in them because it doesn't coat the gears well enough, they recommended Royal Purple or Mobil 1.
    Worthless dribble. The dealership SHOULD always recommend a GL-5 rated fluid, but "brand X doesn't coat the gears well enough" is a worthless comment.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
