Wanted: Opinion on Oils
Results 1 to 15 of 21
This is a discussion on Wanted: Opinion on Oils within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Hey guys, I'm looking to change my diff oil and tranny oil to see if I can eliminate a howling/whine ...
    Registered User Chris G's Avatar
    Jan 2004
    Littleton, CO
    Wanted: Locals Opinion on Oils
    Hey guys, I'm looking to change my diff oil and tranny oil to see if I can eliminate a howling/whine noise I am getting at 60 mph and was wondering what kinda fluids you guys are using. Obviously looking for some sort of synthetic...
    I've heard not to run Mobil1 in the tranny, but it's alrite in the differential...
    ANY opinions are welcome, just thought I'd ask my local friends before I go out and ask elsewhere (and here I will probably get a better response)...
    Thanks, Chris
    2004 PSM WRX Sedan
    AIM:
    XxGoudaxX
    Registered User mourning_air's Avatar
    May 2003
    http://www.awdpirates.net
    I say Redline in both...
    <Ryan>
    '00 Silverthorn Metallic 2.5 RS
    '04 San Remo Red WRX Wagon
    Registered User cnstman's Avatar
    Jan 2002
    Colorado Springs
    valvoline conventional 75-90 all the way around in my wrx, never had a problem.
    checkers carries it, but you may have to go to a few to find enough as they usually only have 1-2 quarts.
    2004 STi
    Silver/Silver
    Registered User WRX Harvey's Avatar
    Near CU
    Subaru has switched to a synthetic GL-5 that is made by GM, it works very well and seems to quiet noisy and help problematic shifting. I recently replaced mine in a transmission Bret had built 16000 miles ago, I beleive he put the synthetic in there and possibly some dexron as a detergent. It came out clear and smelled ok.
    I put the Redline shockproof in my rear diff recently also, 5 teeth came out the drain hole with the stock fluid, which was black as coal after only 62000 miles. I noticed that though the fluid was black, it didn't have any metal in it. I put a light in the little fill hole and looked inside the diff. It was clean with no metal powder, but the teeth were missing from random locations on the planetary gears. The Redline seems to be fine in there and I am just waiting for the rearend to die eventually. My torque is now 265.7 uncorrected, 14psi, at the wheels at MAC. Die Rear Diff Die
    edit- the GM synthetic is more expensive than the Redline. Also, I think you can't use the shockproof in the transmission, only in the rear diff.
    Speed freak
    Registered User Matt Monson's Avatar
    Apr 2004
    Colorado
    I did mine last week and also used the vavoline, but got the 80-90. Walmart has it for less than $4 a quart. Before the change, my tranny was so crunchy that I had to drop to second(at a stop) before it would feed into 1st. Now it is fine. BTW, those are not just shredded synchros in that picture, there are a few teeth that came out of mine...
    MY08 stage 1 WRX
    MY99 stage 28 2.5RS
    MY92 stage -7 Legacy SS
    MY74 914 bumblebee
    Registered User MtnManWRX's Avatar
    Mar 2003
    Other side of the Creek
    Quote Originally Posted by Chris G
    I am just curious were you heard this? I have run Mobil 1 full syn in my tranny, motor and rear diff for over 33 thousand mile with NO problems. I recently changed the tranny fluid, it was clear (well as clear as it can be) and not nearly as smelly from when I drained the stock stuff.
    but each person is different and some cars react differently.
    Jan 2004
    Littleton, CO
    I've read about the Redline oils, but I am not sure which one to go with. Looks to me like the MT90 is GL4, and the 75w90 stuff is GL5.
    Harvey, where did you pick up the Redline shockproof? Seems hard to find around where I am...
    Does anyone know if I can pick up the GM stuff at a local parts store?
    I feel like a n00b
    2004 PSM WRX Sedan
    AIM:
    XxGoudaxX
    Registered User mike270's Avatar
    Jan 2004
    Denver, CO
    Quote Originally Posted by Matt Monson
    [IMG]I did mine last week and also used the vavoline, but got the 80-90. Walmart has it for less than $4 a quart. Before the change, my tranny was so crunchy that I had to drop to second(at a stop) before it would feed into 1st. Now it is fine. BTW, those are not just shredded synchros in that picture, there are a few teeth that came out of mine...
    I'm afraid to flush my tranny now.
    2002 Impreza 2.5RS
    Apr 2004
    Colorado
    The problem with Mobil1 in the tranny is that the synchros want more friction that the Mobil1 provides to function optimumly. With too low friction, they will wear quickly and while you may not have any troubles now, you will likely wear them out quicker that way. This is the reason that I choose 80-90 dino oil for my car with 112k mi on the ticker. My synchros are hurting and I need that viscocity to make them work properly with how thrashed they are. Redline is the way to go if you choose syth...
    MY08 stage 1 WRX
    MY99 stage 28 2.5RS
    MY74 914 bumblebee
    Near CU
    I have an extra quart of the shockproof Redline, it is more than you need for the rear diff. $9 is what I paid including tax. You can have it if you want for $9.
    Speed freak
    Registered User crazycam31's Avatar
    Jul 2003
    Colorado
    I'm using the Redline MT-90 in my trans. The whining thing everyone complains about never bothered me so I really didn't notice much of a difference. Slightly smoother shifting. Also, I only had a small amount of metal shavings that were REALLY fine on the magnetic plug so that was good.
    Registered User analog_909's Avatar
    May 2004
    Laramie, WY
    In my professional opinion as someone certified to do all sorts of crazy things with trannies. Valvoline Synpower 75-90w is absolutely worth it's weight in gold for subaru gear boxes. For rear differentials run Mobil 1 as it will help the diff. run a bit cooler/quieter. The problem with Mobil 1 in the tranny itself is that it doesn't have an additive package that generates enough friction between the synchros. Redline oils aren't GL5 rated (at least last I read they weren't) and can't be ran in subaru boxes without risking some long term damage.
    Jan 2004
    Littleton, CO
    Quote Originally Posted by analog_909
    Matt, thanks for the advice...
    I was thinking about running Mobil1 in the rear diff to begin with but wasn't sure...
    Can this synpower be found at any "normal" autoparts store?
    Thanks a lot guys, I really appreciate it!
    2004 PSM WRX Sedan
    AIM:
    XxGoudaxX
    May 2004
    Laramie, WY
    The valvoline is pretty effing hard to find. However I've found that most NAPA stores carry it. Definately worth the time it takes to run down though.
    Jan 2004
    Littleton, CO
    I know I won't have a problem tracking down the mobil1 gear oil, any parts store carries that...
    I will check with the parts stores around here...
    It's called Valvovine Synpower 75w90?
    2004 PSM WRX Sedan
    AIM:
    XxGoudaxX
