Change To Syn Gear Oil Now! - Page 12
Page 12 of 18 FirstFirst ... 23456789101112131415161718 LastLast
Results 166 to 180 of 269
This is a discussion on Change To Syn Gear Oil Now! within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Notice I said ring and pinion, so it's good in the diff, not the tranny/front axle combo. There you want ...
  1. #166
    Oct 2002
    nj
    There you want to use GL5 spec. Redline 75W90NS, or MT90 GL4 spec that is better in cold weather. I actually run a 50/50 mix. The synchromesh is probably ok, I don't see any problems with some of it in the case, but 100% synchromesh concerns me, since it's not GL 5 rated, as far as I can tell.
    Remember the transaxle houses the synchros and the front diff, so you need to address the needs of the synchros first, and that is no limited slip fluids. Also nothing to thick or you will not be able to shift in cooler weather.
    Do you use the car on the track?
    If so then simply replace fluids often, depending on the number of track events.
    On the street, outside of drag racing all the time, it will be very very difficult to see the difference in all the lubes mentioned above. Besides drag racing will destroy way more than the tranny.
  3. #167
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Redline shockproof IS GL-5 rated. Redline warns that it actually may be too slippery for trannys BUT a lot of people have had good luck stopping grinding with it. Dunno why. Fixed my buddy's Impreza L 3rd gear grind, and I had good luck with it in my WRX (though I didn't have any grinding to start out with.
    I also reckon shockproof is just about the best stuff out there for the rear end.
    C
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
  4. #168
    Jul 2001
    Plains of Eastern Montana
    Quote Originally Posted by GV27
    C
    Chris I can't find GL ratings for any of the shockproof- linky?
    Thanks
    Mike
  6. #169
    Oct 2002
    nj
    ShockProok is fine for open and limited slip diffs, so it makes sense it's GL5 spec lube.
    It also makes senses that it might not have the optimum friction properites for our synchros. I'm worried that not using the right lube for the synchros might improve things for a while but will also cause the synchros to wear faster.
  7. #170
    Registered User Retro's Avatar
    May 2002
    USA, FL
    Quote Originally Posted by Big Sky WRX
    Thanks
    Mike
    I already posted those somewhere on this site and on the nabisco. If you look around long enough on Redline's site they have a pdf that lists it as GL-5.
    clutch, shift, gas, clutch, shift, gas, shift, clutch, gas, clutch gas, shift... oops!
  8. #171
    Jul 2001
    I'll keep looking
  9. #172
    Jun 2002
    Quote Originally Posted by Retro
    Ya know, I saw that same PDF. But when I went looking for it in reference to this thread I couldn't find it again. I wonder if it was a typo?? I just emailed them......I'll let you know what I find out.
    C
    1993 Honda CBR600F2
  10. #173
    Jul 2001
    C
    Sounds good! Would be nice to know (waranty type issues, etc).
    Thanks
  11. #174
    Jun 2002
    Here's the response from Redline:
    Thank you for contacting Red Line Oil, the ShockProof is a special race type lubricant and doesn't carry a GL rating, though they should provide the GL-5 protection levels. The tech report doesn't mention a specific GL rating.
    In the WRX transaxle we recommend the 75W90NS and the 75W90 in the rear differential, both are GL-5 gear oils.
    Regards, Dave
    Red Line Oil
    1993 Honda CBR600F2
  12. #175
    Registered User scooby24's Avatar
    Mar 2004
    Kansas City
    I got the same response from them but many people have had problems with 75w90ns and synchros so I'm going to go ahead and go with shockproof lightweight
    05 Crystal Gray STi
    304 hp 353 lbs on 92 octane ------> Mustang Dyno
    12.6 @ 109.2 > new numbers coming soon.
  13. #176
    May 2002
    USA, FL
    Quote Originally Posted by scooby24
    Are you sure those problems were with NS and not the regular stuff? I catch many people getting confused with NS and the regular version. I actually have the PDF saved that mentions the GL rating of Shockproof.. maybe someone lied or was misinformed. I'll look for it and repost it.
    Edit: Found it on the last page where they list all the individual oils http://www.redlineoil.com/whitePaper/18.pdf They list Lightweight and SuperLightweight as being GL-5.
  14. #177
    Mar 2004
    Kansas City
    Positive. Lots of complaints of the NS as well as the regular. One of my buddies, however has NS + synchromesh and loves it so that sounds like a decent combination. Protection of synthetic GL-5 fluid...plus synchro friendliness of synchromesh.
    05 Crystal Gray STi
  15. #178
    May 2002
    USA, FL
    Actually it's no longer a GL-5 once you add the Synchromesh.
  16. #179
    Jul 2001
    Thanks for the link, but I believe they are refering to their lighweight and superlightweight "normal" gear oils- not their shockproof- which they list right below it- lists no GL rating.
    I do know the shockproof works- for warranty issues- don't know if it would be the best choice- looks like a bluish green from a science fiction show
  17. #180
    Registered User GIRex's Avatar
    Oct 2004
    Oregon
    this whole talk about gl-5 eating at (brass)syncro's makes me think that is the problem with our trannys the whole time(the teeth can be explained from people not knowing how to shift right ie alittle clutch slip while launching.)
    Wouldnt it still be mostly a gl-5 with some gl-4 addidtive? I think im going to drain a quart of the pensoil and add a quart of synromesh(my pensoil is just the synthetic 75-90w)
    Handling: Kyb AGX struts, Tein springs, camber bolts, Alignment -1.3F/-1.0R
    Looks: Gold powder coated stockers, Tint 30%F/20%rear, Infinity speakers, Sony deck
    Future mods: Legacy GT
    Car domain:http://www.cardomain.com/memberpage/852175
