car and steering wheel vibrates when turning left? help!
Results 1 to 5 of 5
This is a discussion on car and steering wheel vibrates when turning left? help! within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; my car shakes a little when i make a left turn at slow speeds. in the middle of my turn, ...
    May 2003
    Bay Area, ca
    my car shakes a little when i make a left turn at slow speeds. in the middle of my turn, my steering wheel shakes and vibrates a little. my car also shakes a little too. this only happens when i turn left. what could it be? my car has only 8k miles. it seems like it's from the steering system or something.
    03 WRB WRX - 5/18/03
    Aug 2003
    Norway, Europe
    Sorry can't help you much, but have you tried to turn the wheel over and looked inside where the wheel is located to se if it hits anything...
    Your should also take the car to the dealer. Because it's so new you should have no problems having them to looki at it..
    Silver -02 Impreza WRX
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Are all the wheel lugs tight?
    If so, take it back to the dealership and replicate the problem.
    -Jim
    Sep 2003
    Canada
    Check your tire pressures. Check lug nuts. Get an alignment (while you're at it get the tire place to check your wheels for being bent). In that order.
    Registered User Retro's Avatar
    May 2002
    USA, FL
    If none of those check your power steering.
