Transmission warranty woes only (problem occurrence log) - Page 4
Page 4 of 18 FirstFirst 1234567891011121314 ... LastLast
Results 46 to 60 of 267
This is a discussion on Transmission warranty woes only (problem occurrence log) within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I lost 8 teeth off 2nd gear at 27k, (I paid for: tranny/clutch/flywheel/labor) I fugure I have another 30k till ...
  1. #46
    Aug 2001
    18355 E Girard Ave Aurora CO 80013
    I lost 8 teeth off 2nd gear at 27k, (I paid for: tranny/clutch/flywheel/labor) I fugure I have another 30k till it goes again......the way SOA is handling the failure of the 5 speed has made me think twice about owning another subaru! I now have a forester 5 spd in my car, feels better than the origional......BTW all imprezas/forester/outbacks have the same 5spd.
    hello Audi/BMW for the next car.
    Nate
    (business closed)
  3. #47
    Arvada,CO
    Nate-who put a forester trans in your car?
  4. #48
    Aug 2001
    might as well be I was just trying to get a point accross
    (business closed)
  6. #49
    Jan 2003
    Southern Arizona
    Red face 'spare' bolt on drain plug magnet
    I was doing maintenance yesterday and planned to change the gear oil to synthetic. Imagine my suprise when I pulled the drain plug oil and found a loose bolt stuck to the magnet. The bolt doesn't look like it was ever run in, but has a couple of small chingos that lead me to believe it hasn't spent it's entire life attached to the magnet. I called the dealer and they assured me that it must have come from the floor in my garage...the battle begins. I can't say that I have any trouble with the tranny, some minor grinding putting it into reverse if I'm in a hurry, but none of the other symptoms listed in this thread. I've attached the same photo that I e-mailed to the dealer...we'll see where this leads.
  7. #50
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
  8. #51
    Mar 2003
    KC
    I have an '03 wagon with 5900 miles. It was in the shop for 1 week with a very loud, speed dependant grinding coming from the transmission. The faster I went the louder and faster the noise. It's hard to describe, but it kind of sounds like poor AM radio reception. Doesn't matter what gear, clutch in or out, accelerating or deaccelerating, noise is always there. After a week of driving a focus I was informed by the dealer that there is something internally wrong with the trans (duh!) but at this point the parts are supposedly on "backorder". They have another WRX in the shop for trans work taking up a rack but they told me to drive it in the mean-time. So, I'm driving it at the moment. No shifting trouble at all, I can get into 1st gear at 20mph. I just hope it doesn't grenade on me, although it might be better to get a completly new unit rather than just some new parts put in this one. I guess I'll have to wait and see
    aquamisted wagon
    12.4 @ 111
  9. #52
    Aug 2002
    Evergreen
    I stripped out the first gear synchro at about 6000 miles. I took the car in for the 7500 mile service. It was replaced no questions asked by John Elway Subaru....even with a TBE.
    1997 VOLVO 850R 14.5@102 with a slushbox and a 2.4 sec 60 ft time.
    1951 chevy 13.3@ 109 gettin some paint
    2002 WRX 13.8 stock turbo :sold
    1996 BMW 318ti what I drive when everything else is broken
  10. #53
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Yeah, Big John has a good shop over there. J.E. West, right?
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
  11. #54
    Registered User WRacergirlX's Avatar
    May 2003
    NJ
    Suggestion...
    I have about 22g's on the car and it is somewhat modified. I have run it at least 50 times at the track with super hard launches and only now am I experiencing problems with the trani which were to be expected from the abuse
    About two/three weeks ago I got a hold of some Redline Gear Oil and changed the gear oil since I was having a little trouble shifting into 2nd gear at hi-RPMs. This helped the sychros out a little by providing more lube than the stock trani oil does. Its not a problem solver but it did help a little.. and when its that bad, a little bit goes a long way..
    Honestly if you guys are daily driving the WRX and are having difficulty with the MT, get some of this oil... it will also help prolong the life of the synchros. Also after driving my friends WRX I've found that the short throw shifter is causing a lot of my shifting problems! Go figure!
    What I really need is a new clutch... damn that money pit!
    ~Chrissie~
  12. #55
    Registered User 0260B4U's Avatar
    Feb 2003
    I rule
    Well, I have 6k on mine, only mods worth mentioning are STi mounts an BOV. getting a grind into 4th whe I shift over 4 grand. taking it in Tues I will update then.
    --Little John--
    Straights are for fast cars...
    Turns are for fast drivers...
    --Colin McRae
    "Power is nothing without control"
    http://static.howstuffworks.com/gif/engine-flat-4.gif
    "Are you OK to drink?"
  13. #56
    Registered User Bayley's Avatar
    Jun 2003
    Farmington Hills, MI
    Angry
    3900 miles and 23 days after the purchase of a BRAND NEW '04 SUBARU WRX 1st and 4th gear synchro are totally shot! About 95% of these miles were highway miles from two very long trips I took during the break in period. Don't let anyone say that "hard, aggressive driving" is the only thing that will destroy these tranny's. Mine is shot from simple day to day driving. Still waiting to hear back from the dealership. I called them this morning (twice) and still haven't heard anything back.
    Anything less than a completely new transmission at 3900 miles is unacceptable to me! I'll post results from the dealership as they occur.
    -Bayley
  14. #57
    Feb 2003
    I rule
    Well I went to take mine in also got my 7500 done, they have the parts.
    Guy that was supposed to do it called in the day beforehis vacation so I wont be able to take it in till NEXT thurs
    --Little John--
    --Colin McRae
  15. #58
    Jun 2003
    Update:
    Three weeks later, I finally received my WRX back from the dealership.
    New:
    1st gear
    1st gear synchro
    3rd gear
    3rd gear synchro
    Hub assembly (???)
    Hmmm... for a simple little synchro replacement, they sure seemed to replace an awful lot of components. I'm not complaining (beyond driving a 'grocery gettin' Forrester for three weeks) but it does seem that Subaru knows more about my problems than what they are telling me.
    -Bayley
  16. #59
    Jul 2003
    Transmission TSB
    Here is my story. At 23000 miles complained about tranny popping out of reverse. Dealer couldn't duplicate it. IT has been gettting worse and now at 55000 miles dealer got it to happen easily. I got a call tonight about a TSB for this issue which includes some bearings and stuff. I'll find out more tomorrow. Get this though because its after the 3/36 they don't want to pay for a rental car. Had it been before the 3/36 they would have covered it. Tomorrow should be fun considing during my search I found the TSB for the clutch issue TSB# 03-51-02. Now I'm going to have them pay for a rental car while they replace my clutch asm and transmission parts. They will pay for my rental car because I reported the problem well before the 3/36 was out. Anybody know of the transmission TSB the dealer was talking about?
    -TJ
  17. #60
    Feb 2003
    I rule
    they replaced my 3rd to 4th syncro and hub assembly with sealant kit and brake cleaner on the list. some other things.
    --Little John--
    --Colin McRae
