Transmission warranty woes only (problem occurrence log) - Page 15
Page 15 of 18 FirstFirst ... 56789101112131415161718 LastLast
Results 211 to 225 of 267
This is a discussion on Transmission warranty woes only (problem occurrence log) within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Superorb I read a few pages of this and am wondering if there's some correct way to ...
  1. #211
    Registered User PJO42387's Avatar
    May 2006
    DF-DUB
    Quote Originally Posted by Superorb View Post
    I read a few pages of this and am wondering if there's some correct way to drive a subaru 5sp. I just came form a honda 5sp which I love, and this Scooby is tough to master. I get loads of chatter going into 1st gear from a stop, and also 2nd gear from neutral. It's really pissing me off that I can't figure it out. So, is there a thread explaining how to drive a scooby?
    Its probly never going to feel like the honda. Your just going to have to get used to it. Give it time and youll master it. 1st and 2nd piss me off sometimes.
    CGM
  3. #212
    Registered User powder's Avatar
    Aug 2006
    WA State
    #1 thing is don't force it. If it's not wanting to go in then let the clutch out in neutral and then try again. If no matter what it grinds, then you have other issues and something's wrong.
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
  4. #213
    Sep 2005
    Tallahassee, FL
    Quote Originally Posted by powder View Post
    I have also had trouble let's say going over a speed bump. I come up to the bump in 2nd gear, then take it out of gear while going over the bump. Then when I goto put it in 1st it won't want to go in, maybe because the car is moving? Also if I'm slowing down to take a corner, and I downshift to a lower gear, it doesn't want to go in, even if I match revs. Sometimes it goes in, but it's always difficult to get it to go in. There is an aftermarket shifter on the car if it makes a difference. It does feel a bit notchy but I'm used to slick Honda gearboxes.
  6. #214
    Aug 2006
    WA State
    Try switching to a synthetic. I use Redline MT90 and it made a world of difference. How many miles are on the car and did you put the shifter in? If you didn't put the bulk of the miles on it and bought it used there is a decent chance that it was abused.
    When you change your tranny oil, dip your hand in the used oil and check for chips off of gears or a really thick film. An abused tranny would have bigger chips and a high mileage would have that film or grease i mentioned cuz over time the particles that come off of the brass syncro's will mesh w/ the oil and create a grease. Also, reach up into the bung hole (huh huh huh, i said bung hole) and check to see if there's a magnet (dunno if subies are equipped w/ one or not) that catches all the chips before they exit and if you can, try to see if there's anything big just sittin there.
    It could just be an old tranny oil thing and that may fix it.
  7. #215
    Sep 2005
    Tallahassee, FL
    It has 72k miles on it and I got it on Saturday. It was easy to change the fluid in the honda, what's involved with changing it in this one? Can I use that GM syncromesh stuff?
  8. #216
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    ***** to get in first gear, it's what makes a subaru a subaru.
  9. #217
    Sep 2005
    Tallahassee, FL
    Quote Originally Posted by BrianH View Post
    Can you type it with spaces so the stars don't take over? Su.cks? It's a PITA is what it is, subaru or not...
  10. #218
    Aug 2006
    WA State
    oil's gotta be a 75w90. that's what's meant to run in this tranny. and yes, all suby's have problems w/ first gear. mine does also. just be gentle and you'll get used to it.
  11. #219
    Sep 2005
    Tallahassee, FL
    I was just curious if anyone's run that GM syncromesh stuff. I don't want to put anything crappy in there. ANYTHING to allow it to run better/last longer. I don't plan on ragging this out, it needs to be a reliable daily driver to haul me and my crap around and look nice doing it
    Where can I find a how-to on flushing the tranny fluid?
  12. #220
    Registered User hksimprezawrx's Avatar
    Jul 2004
    so.cali
    thought ide inform you that 3 months later my tranny pops one more time... bye bye 1st and 2nd gear... any way, this is the third tranny to break....
    1st @ 1,500 miles
    2nd @ 33,000 miles
    3rd @ 36,000 miles
    fruck this and fruck subaru.. im parting out my car who wants what i gots....
  13. #221
    May 2006
    DF-DUB
    ^^^That sucks
    Whats you mods and what year is the broken suby?
    CGM
  14. #222
    Jul 2004
    so.cali
    click my avatar.... all information and mod list is up to date and correct
  15. #223
    Registered User cliffordbg's Avatar
    Oct 2005
    North Dakota
    Wow someone else with tranny problems. I'm on my 3rd tranny being installed. CV coupler busted and went through the tranny. Anyone ever seen that before???
    Cobb AP stage 2
    Perrin TBE with uppipe
    GP MOTO TMIC
  16. #224
    Mar 2007
    wuts up guys im new here but I was talking to some kid today about WRX's and sti's and i was interested in the wrx b/c i want to buy one but he kept telling me that the wrx transmissions are shyt and that the sti transmission is soo much more reliable than the WRX. Even a normal driver will go threw 2 tansmissions, why is this. Would you guys recommend getting an STi over an WRX, b/c i didn't want to spend more than $18,700,000 and i know that the STi is faster 6 speed and all that, but besides that whats makes the STi's tranny sooo much better.
  17. #225
    Registered User tayhadar1's Avatar
    Apr 2006
    Spokane, WA
    a retard will go threw 2 transmissions driving normal. there are plenty of people on here with lots of horsepower that are still on stock tranny and then there are others that are almost stock and blow the tranny. it is all how you drive and how hard you shift and whether or not you launch. that being said the sti transmission is totally different as it can handle a lot more abuse, but then again it is not invincible.
    2004 WRX Sti Cobb Stage 2
    GO COUGS!!!
