Shifter popped out of 3rd
Results 1 to 3 of 3
This is a discussion on Shifter popped out of 3rd within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I was taking a wide right turn at 40 and in 3rd. While in the middle of the turn, the ...
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    I was taking a wide right turn at 40 and in 3rd. While in the middle of the turn, the shifter came out of 3rd as I was holding onto it without me depressing the clutch. Is this bad, or did I get it at the moment when the gears were lined up for it to do that?
    Fahd
    Floats like a butterfly and stings like when I pee!
    Registered User flsRocksYou's Avatar
    Nov 2002
    Milwaukee
    You're fine. You can pull the car out of gear without the clutch fine as long as you're not giving it gas (if you were you'd probably grind the gear a bit). If you didn't grind it, don't worry.
    Current mods on my 2003 Silver WRX: Autospeed Flex Uppipe, Perrin Downpipe w/cat, TXS UTEC, Goodrich Stainless Steel Brake Lines, TXS HPBC [15.9 PSI]. Valentine One. Tuned by God. Silencer Free.
    Jun 2002
    Houston, TX
    Yeah, no grind. Thanks man
    Fahd
