I mixed up a batch of "Uncle Scottys Cocktail" but a full synthetic version in my 06 TR at 15k miles.
1 qt Redline lightweight shockproof
1 qt Amsoil syncromesh
2 qt Amsoil 75w90 gear oil.
NOTE: 5MT CAPACITY IS 3.8 QTS USE GEAR OIL AS TOP OFF FLUID. DO NOT DUMP IN ALL 4 QTS. PUT IN 3.25 AND CHECK ETC.
I have been using it for 10,000 miles and it works 10x better than stock. Took away the notchiness of the shifts, engages smoother etc. Note: 06 5MT tranny's shift slightly better from factory than the 02-05 5mt due to a slight redesign. Therefore the change wasn't as drastic as it was in the 02 below.
Also mixed the normal "Uncle Scottys Cocktail" from Nasioc and put it in an 02 bugeye 5MT at 40k miles.
Previously it had been filled with fresh Valvoline 75w90 gear oil. Shifting with Valvoline was awful, first gear ground every time on the 2-1 shift and reverse felt impossible to find.
So we put in USC which is:
1 qt Syncormesh fluid (pennsoil, gm or amsoil)
1 qt redline lightweight shockproof
2 qt castrol Hypoy C 80w 90 gear oil.
Worked amazing. Felt like a miracle cure. First gear shifted up and down like it was double syncroed, reverse was easy to find consistantly, and shifting was way smoother. I highly recommend it on 02-05 5MT's. Been using for 3-5 k miles now with no decrease in performance.
Vendors for USC:
Togg's
http://www.tognottisautoworld.com/de...ookieSupport=1
They have everything to make a full syn version, and carry Most major brands of synthetics for you die hard M1, Redline, Royal Purpal, Kendall, Castrol, Valvoline, Amsoil, etc. SYNTHETIC fans.
Pepboy's sells the Castrol Hypoy C as well as the Pennzoil Syncromesh.
www.amazon.com also sells the ingrediants.
Also check your local vendors.
LinkBack URL
About LinkBacks
rock!)
