Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
This is a discussion on {{Official Trans Fluid Thread}} within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Originally Posted by sch3838 hmmm i dont get it, which mix is better? sorry im a noob thanks They both ...
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by sch3838 View Post
    sorry im a noob
    thanks
    They both work great thus far. One is just a synthetic formulation for the synthetic fans and the other is a Dino equivalent. They both are a dramatic improvement.
  2. #17
    Registered User jaqattack02's Avatar
    Sep 2005
    Richmond, Va
    Anyone tried the Extra S from Subaru yet? Rumor a while back was that they use it in one of their race cars. It comes in a big drum from Subaru (5 gallons or something like that) for about $100 bucks. That's what I plan on putting in mine in the near future.
    Blobeye Syndicate #035
    Cobb Stage 2
  3. #18
    Mar 2007
    delaware
    anyone tried 75w-90 lucas synthetic gear oil?
  4. #19
    Sep 2005
    Richmond, Va
    How about Neo Gear oil? They claim to be used by a number of racing teams. From their website.
    Used in F-1, IRL, Champ Car, ALM, NASCAR
    Here's the site http://www.neosyntheticoil.com/gear_oil.html
    Looks like it's pretty expensive stuff. I found it here for $80 per gallon. http://bakerprecision.com/neocirc.htm
    Although that's for the RHD oil, which is designed for racing. I can't find the regular HD oil for sale anywhere.
    Cobb Stage 2
  5. #20
    Registered User SubieStylez's Avatar
    Mar 2006
    Saugus, MA
    what do you guys use in the rear diff??
    Sold the WRX bought a '06 Evo IX MR and sorry to say never looked back
  6. #21
    Registered User 68sprintb's Avatar
    Dec 2005
    Cupertino, CA
    i used uncle scotty's cocktail for the trans and Mobil1 75W90 synthetic for the rear differential
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / Scooby Sport New Age centre pipe & backbox
  7. #22
    Registered User WRXcruiser's Avatar
    May 2005
    Seattle, Washington
    putting in uncle scottys cocktail this week for my 02 tranny (everything ordered from amazon) and i used redline in my rear differential about 4 weeks ago
    cant wait for the improvement of USC since my gears have been stubborn lately with the cold weather
    2005 WRX Wagon stg 1 - 3/12 to present
    1996 BMW 328is coupe - 5/11 to present
    02 WRX wagon stg 2 - history
    WTB: Cobb Accessport ap-sub-001 for 2005 WRX
  8. #23
    May 2005
    Seattle, Washington
    wow!!! USC has done wonders for my 02 tranny...
    before: grinding, hesitation accepting gears, forget about reverse unless you roll forward first, drove horrible with the engine cold....i really thought i was going to see the end of my transmission
    after: no grinding, no hesitation, smooth between shifts, always takes the gear except 1st sometimes in a roll w/o double clutch (havnt tried w/ double clutching, probably works though), always get in reverse if the engine is warm
    transmission feels brand new again...experiencing other problems now as a result of taking my IC off to get to the fill hole next time im using a funnel with a hose connected instead of taking the IC off
  9. #24
    Jun 2006
    Nor Cal
    Quote Originally Posted by WRXcruiser View Post
    Yeah I use the double funnel technique.
  10. #25
    Registered User Yossarian's Avatar
    Jan 2006
    Ohio
    I use BG synchroshift II.
    Huge improvement over whatever the factory put in there.
    ~Selah
  11. #26
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    1) Stock factory fluid: no real issues. Shifted just ok.
    2) At 10,570 miles I changed out the rear diff to M1 75w90 and the front/tran to USC (original formula). It's so easy to do these changes, I might just do it again at 20k (lol).
    I let it drain on level ground for about 3hrs, but the initial 3.25 qts filled it right to the middle of the dipstick. After a day of driving, it still reads in the middle, so yes... make sure you don't put all 4 qts in.
    1 qt Pennzoil Synchromesh (pep bys)
    1 qt Redline Lt Wgt Shockproof (amazon)
    1.25 qt Castol Hypro C 80w90 (pep bys)
    T-70 torx bit (amazon)
    Measured funnel w/ hose (pep bys)
    The fill order was Syncromesh, Redline Shockproof, and Castrol, with the top-off (.25qt) being Castrol.
    The verdict? I notice a very real improvement right away in all gears. Smooth as silk. Maybe say a 50% improvement?
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
  12. #27
    Oct 2007
    I've got an '06 2.5i wagon, and never really had a problem with the stock fluid, shifted fine maybe a little "notchy" at times.
    I changed my tranny fluid at 35k and put in USC, not because I was having problems shifting but because I'd read that its pretty good for curing "notchyness" so I figured it would be like preventative maintenence. It's holding up fine after 6k, even when I double clutch down to first smooth as butter. Reverse doesn't want to slide in sometimes on the first start, have to let it roll back about and inch then no problem. I'm thinkin of trying just the redline combo next time, maybe at 45k if I have some extra money.
  13. #28
    Registered User yo vanilla's Avatar
    Nov 2004
    appleton, wi
    cobb used to have a good fluid type comparison on their website but now i cannot find it. but judging by some of the posts here it would be valuable - for instance some fluids have additives that are easy on your syncros but wear your bearings more, and vice-versa.
    so thats to say that if you use a fluid that makes your syncros fly real smooth, you could be doing long term damage to your bearings; couple of people mentioned using race fluid and my first thought is that race cars are meant to perform but are not meant to last any longer than they have to...
    07 WRX TR | 03 mazda6
    man a whole mess of nachos sounds good right now
    ***Hawk-Eye Alliance #95*** Kachow!!
  14. #29
    Registered User farBeyondDriven's Avatar
    Sep 2006
    West Deptford, NJ
    Quote Originally Posted by yo vanilla View Post
    Interesting. Does anyone know anything more about this?
    2006 Panty Dropper
    "I want to die peacefully in my sleep, like my grandfather. Not screaming in terror like his passengers."
  15. #30
    Registered User walter451's Avatar
    Nov 2007
    austin
    the USC
    Hey guys I have an 05 4EAT. Will the USC mixture be right for me? And if it is can you list what is in the mixture.
    Thanks
