Exedy Stage 1 clutch, and ACT prolite flywheel
Results 1 to 11 of 11
This is a discussion on Exedy Stage 1 clutch, and ACT prolite flywheel within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I have an 02 wrx with a cbe eventually going tbe and stage 2. My clutch is about to go ...
    Sep 2006
    Washington
    I have an 02 wrx with a cbe eventually going tbe and stage 2. My clutch is about to go out so I am getting some prices. Would it be a good idea for me to get the Exedy Stage 1 clutch kit with an ACT prolite flywheel. It's only 739 so it's not that expensive.
    Registered User 4cyturbowrx's Avatar
    Nov 2003
    philly
    Not sure how many miles are on your car, but i wouldnt move up to a harder clutch with just a stage 2. Your trans will most likly brake with any type of hard shifts. I had my stock clutch last stock for about 15k stage 2 for another 15k and stage 2.5 for another 46k then he clutch went. But as soon as i put a stage 1 clutch in i broke my trans with in 3k just on the stage 1 clutch. MY02 just stay with the stocker.
    Sep 2006
    Washington
    it has 69 thousand miles. The owner of the clutch shop recommended going for the stage 1. He said that it will last quite a bit longer than the oem clutch, but going any higher of a stage will break the transmission. He also said that I needed to get a new flywheel so I figured why not get a lightweight flywheel. There is the ACT lightweigh flywheel or the prolite. What are the pro's and cons? Also he has not pulled the clutch out yet, he just said in his experience he has never been able to resurface the flywheel.
    Registered User le wagon's Avatar
    Jul 2005
    SoCal
    i would keep the stock flywheel.. just take it to napa or carquest to be resurfaced for like $35
    supposedly there are misfires with a light flywheel, so IMO why spend more money to have more problems..
    EVO III 16g'd wagon
    stock tranny goin strong
    .. already ready for a bigger turbo
    Quote Originally Posted by chanwahyaoh
    Sometimes after I go poo, I just blank out and mindlessly continue my upward wipe all the way up the small of my back and end up smearing brown all over myself. Just kidding. That sucks about your laundry though...
    Sep 2006
    Washington
    exedy stage 1 organic clutch kit or exedy oem clutch kit?
    Registered User PJO42387's Avatar
    May 2006
    DF-DUB
    Quote Originally Posted by 02BoostedPower View Post
    I would get an OEM clutch, less stress on the gears.
    CGM
    Sep 2006
    Washington
    He said that it with a stage 1 i would be okay for stress on my gears, but the stage 1 would last a lot longer than the oem one. and if I went with the oem should I get the ACT streetlite flywheel?
    Registered User jaqattack02's Avatar
    Sep 2005
    Richmond, Va
    I guess it just comes down to who you would rather trust. The guy who will be doing nothing besides putting in your clutch, taking your money, and may have never seen a WRX before in his life. Or the people who also have the cars, and been there and done it already.
    Blobeye Syndicate #035
    Cobb Stage 2
    Nov 2003
    philly
    You said 69K at stage one on an 02 is not that many miles, with not that much power. Its alot cheaper to replace something stock if your not going to up grade power. I never had a problem with my light weight fly wheel, then again i really didnt get to drive my car that long before i broke my trans, with the upgraded clutch. I would just go with a stock clutch and put in a light weight flywheel. Change everything you can while the trans is down, it will save you 500 to 600 bucks down the road. "Dont treat it like you stole it"
    Sep 2006
    Washington
    thanks for the help everybody, I went with the oem clutch and the streetlite flywheel. Hope everything works out good.
    Registered User subaru_crazy's Avatar
    May 2004
    NYC
    My clutch is going now as well I have 70K I am was going to go with a stock replacement flywheel to complement the new clutch, is it worth going with a lighter flywheel? I know it will make the engine gain rpms faster but how much power would that translate on a WRX? Anyone care to chime in?
    MY LUG NUTS NEED MORE TORQUE THAN YOUR HONDA MAKES!!!!
    Cobb Stg 2 helix up/dp combo
    Kartboy short shifter
