I have a 2007 wrx limited and I was having trouble getting into gear at stop signs or down shifting I was able to pump the clutch a few times and get it to go. Now after I start the car and try to put it into gear it won't go into gear with the car running I thought it was the slave cylinder so I got a new one and found a pin hole in the rubber line to the slave and replaced that and bled the system out and still have no luck does anyone have any suggestions or tips I'm starting to think it might be something with the pressure plate but I'm looking for tips before the trans comes out
