Resistance going into 1st gear. 2011 wrx
Results 1 to 15 of 15
This is a discussion on Resistance going into 1st gear. 2011 wrx within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Hey everyone! I bought a 2011 WRX with 41k on it. I've driven a few manuals but this one is ...
    Oct 2014
    MI
    Hey everyone! I bought a 2011 WRX with 41k on it. I've driven a few manuals but this one is a bit weird and I'm not sure if it's normal. I drove the car a few times with no issues and today I had resistance going into first gear and a little resistance going into second. I'm new to manuals so I'm not sure where to begin. Any help would be great! I searched and couldn't find the problem listed. Thanks!
    May 2007
    orlando flawduh
    When you tried to go into first, were you at a complete stop?
    desiree
    Oct 2014
    MI
    I was at a complete stop and I've tried at a slight roll. It also does it occasionally going into second.
    Registered User speedsterX's Avatar
    Jun 2012
    Alabama
    If it's not grinding and if you're not forcing it, then I wouldn't worry about it.
    Oct 2014
    MI
    Okay. I wasn't sure if it was normal or not. I've been gentle with it. since it's used im not entirely sure what's the deal with it. What color should the trans fluid be if it's been in there for a while? It's just going to take some getting used to. Thanks for the quick replies also. It is greatly appreciated.
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    Quote Originally Posted by mioutback4 View Post
    If it's been in there for a while it'll be leaning towards amber.
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
    Oct 2014
    MI
    Wow. That was the opposite color i had expected. It's grey right now. Thanks.
    Sep 2013
    WV
    ...grey?..flush that.
    Oct 2014
    MI
    I appreciate it. Transmissions are my grey area that scare me. The dealer said it was all good. Then I pulled the dip stick to the trans and grey.
    Jun 2012
    Alabama
    Yeah, changing the fluid should hopefully make a big difference.
    Oct 2014
    MI
    What would a bump feeling be in the shifter?
    Apr 2015
    ny
    I have a similar experience with my 1st gear shift. Almost like it catches once then again when further pushed. I haven't checked the fluid though but did order to change out I'm I at 61k miles. Going to be doing. Most of the 60k maintence myself
    Oct 2014
    MI
    When I test drove the car it came straight from the owner to the dealer. No maintenance. I'm wondering if the previous owner had additive in the trans or if the bushings are quite worn. The fluid is clear and clean. Still hard to get into first. It feels notched out almost.
    Oct 2014
    MI
    I'm beyond scared it's my synchro....
    Aug 2014
    Zanesville, OH
    Mine can be a little bit stubborn going into first, but I wouldn't call it "resistance". When at a complete stop, sometimes it's a little tricky to get 1st and reverse to line up the teeth and get a smooth shift. Just leaving it in Neutral and letting out the clutch and then trying again does the trick to get the gear teeth to get better lined up. I don't have any problems getting into second though.
