Reverse disengages when backing up in snow.
Results 1 to 6 of 6
This is a discussion on Reverse disengages when backing up in snow. within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; We got a bunch of snow here in Boston so I've had to give the car a little bit more ...
    Registered User KRowe's Avatar
    Nov 2011
    Mattapan
    We got a bunch of snow here in Boston so I've had to give the car a little bit more of the beans than usual just to move in the conditions. I noticed that if I exceed 2-3 000 RPM in reverse or try to clear a small mound of snow the gear will disengage and pop into neutral. I'm about to take it in for service but I'm hearing that this may be "normal" for the 5MT because there is no syncro for reverse. I tried doing a bunch of searches but nothing is conclusive so I figured I'd start something here.
    The car does have a Kartboy Short Throw NB* clearances for gear engagement are fine. and I'm using motul 75W Gear 300 transmission fluid. NB* It has been mentioned that transmission fluid can affect the holding power of reverse.
    Drive Hard, Stay Driven..
    Nov 2011
    Mattapan
    Took it to the dealer today; they were able to replicate the gear failure. I've been asked to come back on Tuesday to obtain a rental while they pull the transmission apart.
    Aug 2012
    Tucson, AZ
    Dam that's a pain. Honestly all I can think of first off my mind is the clutch fork. Only because I was skimming diagnosis in my repair manual one day
    Stinkeye member 520
  5. #4
    Nov 2011
    Mattapan
    Andddd broken tooth on reverse. Being repaired under warranty apparently.
  6. #5
    Registered User irickchad's Avatar
    Sep 2013
    WV
    Quote Originally Posted by KRowe View Post
    Glad they fixed it. Do you have any mods, or is it just stock for stock?
  7. #6
    Nov 2011
    Mattapan
    None on the drive train and engine.
