Transmission help
Results 1 to 6 of 6
This is a discussion on Transmission help within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I have a 02 wrx and the tranny blew and I just bought a 03 wrx trans from my work ...
    Nov 2014
    Transmission help
    I have a 02 wrx and the tranny blew and I just bought a 03 wrx trans from my work . Do I need to get the diff and axles out of the 03 or will mine work ?!
    There was a gender change around that time on the front axles. It's safest to look and make sure. In any case check the codes, they're not just in the gearbox but also on a plaque on the fender.
    Nov 2014
    Well I can't check the fender on the 03 cause it's already gone . Do u have any info on the diff ?
    The rear diff?
    The output ratio of the gearbox will determine which rear diff you will need. There were changes but I don't believe they happened during those years (if you are dealing with a US model donor and receiver car).
    Transmission FAQ: Read if you are thinking of upgrading! - Subaru WRX Forum
    http://forums.nasioc.com/forums/showthread.php?t=665334
    WRX tranny compatibility? 02 03 04 05....
    Nov 2014
    How do I figure out the output ratio ? I pulled my rear diff as well and it says 3.79 on the ring and pinion ... I thought 02-05 is 3.54 ..!?
    Check the gearbox code and year of the source car; sites have charts.
