06 STi transmission swap
Results 1 to 3 of 3
This is a discussion on 06 STi transmission swap within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; So I recently blew my trans in my 2006 wrx and was looking into doing a six speed swap. Ive ...
    Jul 2014
    So I recently blew my trans in my 2006 wrx and was looking into doing a six speed swap. Ive read a few forums about the swap but I havent seen anything on an 06 sti trans in an 06 wrx. I just need a clear list of what I need to do an 06 to 06 swap.
    Jul 2014
    I found this, can anyone confirm?
    06 USDM Sti 6 speed:
    -transmission
    -driveshaft
    -Stock R160 can be used without changing the gear ratio due to change in 06 that makes the ceneter diff a 1.1:1 vs the old 1.0:1
    -stock rear axles can be used on rear due to no need to change the rear diff
    -front...04 Sti Axle stubs can be ordered along with seals and clips that retains the WRX front Axles, hubs, etc? Special seals are needed. Axle Stub Part Number: 38415AA110
    Circlip Part Number: 805329010 from Wrinkleboi's thread about this***
    -6 speed shifter and assembly****
    -DCCD controller optional**
    -6-speed clutch fork and slave cylinder?
    -5 speed and 6 speed clutch and flywheel
    Jul 2014
