4th gear grind
Results 1 to 5 of 5
This is a discussion on 4th gear grind within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I noticed the other day that when I upshift to 4th it grinds a little bit like I dont have ...
    Apr 2014
    Edmond, OK
    4th gear grind
    I noticed the other day that when I upshift to 4th it grinds a little bit like I dont have the clutch in all the way but I do. I can downshift from 5th and it goes smoothly, this only happens when upshifting, what could it be? I drive a 2008 WRX Sedan
    Registered User trama's Avatar
    May 2014
    Sonoma coast, CA
    Nastiness! I hope it is just something in the linkage and not the trans. Successful downshifts are encouraging.
    Feb 2014
    PNW -WA STATE - rainy side
    What fluid are you running?
    Apr 2014
    Edmond, OK
    I don't know what the fluids are, I've only had the car for a couple of months and honestley don't know too much about the ins and outs of it. The downshift is only succesful when the RPM's are under 2500. I aw that someone else was having the same problem on here too.
    Feb 2014
    Do a tranny fluid swap and get back with us.
