6 speed swap
Results 1 to 10 of 10
This is a discussion on 6 speed swap within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; alright the time has come my fellow wry friends, time to get the 6 speed swap done!! just want to ...
    Jan 2014
    SLC, UT/ LA, CA
    6 speed swap
    just want to know everything ill need to do the complete swap besides the obvious things
    -trans
    -axles
    -sti brembo
    -rotors/hub assembly
    -rear diff
    any help is appreciated
    2007 Impreza WRX
    1991 UCF 10 VIP
    Jun 2014
    DCCD controller. Aftermarket or OEM.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Technically, you don't NEED the DCCD controller, though without the controller the DCCD will revert to "open" and the trans will only use the Torsen center. Also, be careful with which 6MT you purchase. Most JDM STi 6MTs do not offer the DCCD as this was an option for STis in Japan and/or Type RAs over the years.
    Depending on the year of the car and year of the trans, you will also need a new driveshaft.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Master swap list for 04-07 Sti 6 speed into WRX - NASIOC
    That is the thread for you. Basically it depends on what transmission you get what your parts list will be exactly.
    Some excerpts:
    "04 USDM Sti 6 speed:
    -transmission
    -driveshaft from an automatic or from Sti with a yolk for a wrx
    -3.90 R&P gear to replace the 3.54 in the WRX
    OR
    -R180 rear differential and Sti hubs, rotors, brakes and axles*
    -6 speed shifter and assembly****
    -front axles and hubs can be reused provided the transmission still has the axle stubs in it.
    -DCCD controller optional but recommended**
    -6-speed clutch fork and slave cylinder?
    -5speed or 6 speed flywheel and clutch"
    "05 USDM Sti 6 speed:
    -transmission
    -driveshaft
    OR
    -hubs or Stubs? Not clear on this one for the front but it seems there is extra that needs to be done with an 05***
    -5 speed or 6 speed clutch and flywheel"
    "06 USDM Sti 6 speed:
    -transmission
    -driveshaft
    -Stock R160 can be used without changing the gear ratio due to change in 06 that makes the ceneter diff a 1.1:1 vs the old 1.0:1
    -stock rear axles can be used on rear due to no need to change the rear diff
    -front...04 Sti Axle stubs can be ordered along with seals and clips that retains the WRX front Axles, hubs, etc? Special seals are needed. Axle Stub Part Number: 38415AA110
    Circlip Part Number: 805329010 from Wrinkleboi's thread about this***
    -DCCD controller optional**
    -5 speed and 6 speed clutch and flywheel"
    "07 USDM Sti 6 speed: into wrx
    -transmission
    -driveshaft
    -6-speed clutch fork and slave cylinder for 2007 sti
    R160 rear diff (02-05 wrx)
    Circlips from 2004 sti, oil seals and axle stubs"
    Jan 2014
    SLC, UT/ LA, CA
    Quote Originally Posted by SKI.WRX View Post
    Some excerpts:
    -transmission
    OR
    -transmission
    -driveshaft
    OR
    -transmission
    -driveshaft
    -transmission
    -driveshaft
    Thanks, I've gathered some parts so far and does the year matter? or is it like most parts where 04-07 all basically work
    and will the R180 work the 07? as that is the rear diff option i am going for
    2007 Impreza WRX
    1991 UCF 10 VIP
    Apr 2014
    Southern California
    Does Any one have a list like these of what a 2014 WRX would need to swap from stock 5 speed MT to a STI 6 speed MT?
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by jboadway View Post
    Sure:
    -One 2014 STi
    2011 STi Build Log
    Apr 2014
    Southern California
    If there would have been any in Southern California I would have, I impulsed a hatchback because I love the lines of the car so got one of the last 2014s that was delivered in my area. I kinda just jumped into the wrx so I'm very very new to what you can and can't swap between the wrx and the sti.
    May 2010
    Pittsburgh, PA
    Time to do some reading and searching on forums =)
    2011 STi Build Log
    Jun 2010
    Colorado
    Quote Originally Posted by dirtydriftnutz View Post
    Read that thread. It answers your questions.
