grinding into 4th ?
Results 1 to 15 of 29
This is a discussion on grinding into 4th ? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; so I bought a 09 WRX limited with a 5 spd used with 50,000n kms on it & it shifted ...
    Mar 2014
    Alberta - Canada
    grinding into 4th ?
    so I bought a 09 WRX limited with a 5 spd used with 50,000n kms on it & it shifted fine , thought I would change all fluids & dropped the fluid(not sure what the dealer put in it) & put full synthetic amsoil gear lube 75W-90 & in the trans & now im noticing that from 3rd - 4th theres a grind into gear . ? is there a special ani friction diff additive that your supposed ?
    Thanks
    Aug 2012
    Tucson, AZ
    The 5 speeds typically don't like anything other then subaru synthetic extra s. I thought about running redline but heard a lot of mixed reviews good and terrible...Most of the good ones were sti specific anyway.
    Once I put extra s in my front diff became quiet again and shifting is smooth again.
    Sent from my SCH-I545 using Tapatalk
    Stinkeye member 520
    Mar 2014
    Alberta - Canada
    so i talked to 2 different dealers & with out telling them what i was driving , just explaining the situation , both asked if it was a WRX , one siad that they use "semi-synthetic" & the other siad just regular 75-90 GL-5 . any one heard of this before ?
  5. #4
    Aug 2012
    Tucson, AZ
    Just use extra s from subaru or Fred beans where I bought mine. Redline has reviews of being good for a short while before it breaks down and people report of it being milky, so just any regular 75-90 is no good. I've used my dealerships 75 90 and my diff started whining.
    You could also try running synchro mesh (forgot the brand) but it's supposed to help for smoother shifts. Haven't tried it though. Again my car is running much better with Subaru synthetic extra s 75 90
    Stinkeye member 520
  6. #5
    Feb 2014
    PNW -WA STATE - rainy side
    Don't use a "synchromesh" type product! Maybe OK shifting but not enough protection for the front differential gears.
    I say use a synthetic 75W-110 GL-5 and get back with us.
  7. #6
    Extra-S is expensive. Regular Valvoline GL5 75W-90 will work. Numerous threads.
    Les jeux sont faits.
  8. #7
    Mar 2014
    Alberta - Canada
    Quote Originally Posted by Oilypablo View Post
    Ya , im a little nervous experimenting with another expensive full synthetic....i have already put Amsoil full synthetic 75w-90 in & full synthetic Pennzoil 75w-90
  9. #8
    Feb 2014
    Yes. I'm an Amsoil guy and I even say no to the 75W -90.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  10. #9
    Mar 2014
    Alberta - Canada
    ok , so why the 75w-110 then instead of the recommended 75w-90 ?
  11. #10
    Feb 2014
    Quote Originally Posted by surreyboy View Post
    All about starting viscosity and viscosity retention range. The range of 18-20 cSt hot seems like a sweet spot as long as the fluid has the correct frictional and dynamic viscometrics. If you look at Amsoil's recommendation they give a choice.
  12. #11
    Starting viscosity would be identical for the 75W-90 vs. the 75W-110. I suppose if your car has a splash system it'll be fine but I'd hesitate to use the 110 with a pumped gearbox without contacting the gearbox maker first.
  13. #12
    Mar 2014
    Alberta - Canada
    hey guys , thanks for all your suggestions & advice ! its much appreciated
    so im starting to think its more than just the fluid , i havent changed it yet but was out this afternoon & noticed the the grinding is happening from 3RD into 4TH above 2500-3000 RPM . If i hold the clutch in & let the RPMs drop below 2500 RPM it shifts no prob . is not extreme grinding but none the less , its grinding & i want to fix it
  14. #13
    Provided you have no mechanical problems with the clutch, linkage, or gearbox itself, changing the fluid is still the first thing to do.
    If you have mechanical problems, the fluid is not likely to be the greatest of your worries anyway. I'd give the fluid a try and see what you think first.
  15. #14
    Mar 2014
    Alberta - Canada
    well as far as i know , everything is solid , it drives & changes gears excellent aside from the grind from 3RD to 4Th....i live in the country & went into the closest small town today & they only had 80w-90...is there much difference from 75w-90 ? ill head into the big city tomorrow & see what i can find.
  16. #15
    Registered User G0ATLIF3's Avatar
    Mar 2014
    Alberta Canada
    What city are you close too? Im in the Calgary area, and could point you to a few shops.
    Although i dont think there is a surrey in AB...
