Reverse polarity on traction control button
Results 1 to 10 of 10
This is a discussion on Reverse polarity on traction control button within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; On my 14 limited wrx, I want to bypass the traction control all together, or make it so it's off ...
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    On my 14 limited wrx, I want to bypass the traction control all together, or make it so it's off every time I start the vehicle until I decide I want it.
    As all of you know, the traction control is on as soon as you turn the car on. Even if you disable it, if you turn the car off, it's on again the next time the car is started.
    So does anyone know how to reverse it or bypass it altogether?
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    I'd just press the button to turn it off. I'd like the sport# to be on every time I start my car too, but I just got into the habit of turning the knob to it when I start the car, and now I don't even realize I have done it (sometimes I remember "oh no I have to put it in sport#" and I look down and it is already in it). Pushing the button isn't that hard. Don't be lazy
    Mar 2014
    Oceanside,Ca
    If anybody has any useful advice, I'd like to hear it.
    I would like for it to be off automatically upon start up.
    Mar 2014
    Oceanside,Ca
    Found someone who knows how to do it.
    Traction Control Bypass | Overland Designs
    Feb 2014
    PNW -WA STATE - rainy side
    you will start off with the butting disabled instead of enabled.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by 100plus2Vegas View Post
    Careful with your tone. You're a newbie around here and indirectly insulting a senior member.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Sep 2005
    I'd just put a relay on the e-brake... that way whenever you put the e-brake down, it trips the relay and registers as a press on the traction control button.
    You only want it to be a momentary press though, because if you hold it down, it turns off the TC light, and permanently enables TC until you restart the car.
    Mar 2014
    Oceanside,Ca
    Zax, did you read the post I wrote? I asked for information on how to do something, because I did a search and found nothing. I asked for information, because admittedly, I did not know how to do the modification in question.
    Did you read 11blackSTI's response? Instead of admitting he did not know how to do the modification, or just not replying, he instead encouraged me to push the button and not be lazy. Is that informative?
    Thank you for your reply.
    Nov 2012
    I meant no harm, but once in a while we pull each other's chains on here. You got a free bump by it, and actually solved your own dilemma. I'd say it worked out well.
    zax
    zax is offline
    Nov 2008
    Enjoy the forum.
    Facebook me here
