Drain Bolt Magnets?
Results 1 to 4 of 4
This is a discussion on Drain Bolt Magnets? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I'm about to change the juices in my 2014 WRX tranny and differential. Do the drain plugs have magnets? If ...
    Feb 2014
    PNW -WA STATE - rainy side
    Drain Bolt Magnets?
    If not I would like to add magnets like my engine drain plug. TIA.
    Feb 2014
    I ordered the Dimple brand plugs. I have my doubts about fit. Hmmmm.
    Jan 2012
    New Jersey
    my 2012 has magnets im guessing its the same for the 14. You will still need the large torx driver for the front trans fluid plug. Though if you were to get anything I would buy the correct tool for the rear diff fluid. Yes you can get away with a 1/4in driver but to fit correctly get the tool. If this was what you ordered http://www.rallysportdirect.com/Dimp...lug-3-4in-JNPT they You should get 2 and you can then use either for the fill and drain plug.
    CFLip2x 2012 WRB WRX Build
    Aug 2012
    Tucson, AZ
    Usually in most cars the drain plug will have the magnet for diffs. Our transmission is the same way
    Sent from my SCH-I545 using Tapatalk
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
