2015 WRX Factory STi Short Throw Shifter - Page 2
Results 16 to 30 of 31
This is a discussion on 2015 WRX Factory STi Short Throw Shifter within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Originally Posted by cflip2x Just a very basic FYI on how short throws work. Thanks for explaining that. If we ...
    Jan 2014
    Quote Originally Posted by cflip2x View Post
    If we go for an after market short throw, does it move the fulcrum up or it just shortens the rod above the fulcrum?
    Jan 2012
    New Jersey
    It depends on the manufacturer but usually both height and throe get shortened.
    Sent from my SCH-I545 using Tapatalk
    CFLip2x 2012 WRB WRX Build
    Jan 2012
    New Jersey
    Cobb has made adjustable shifter the last few models so odds are they will do the same for the 2015+ I like the height of the faculty option for my 12. Since I got the arm rest extension my hand rests comfortably on the shifter and arm rest. I would like the height to be shorter only for looks. I don't know how I would like it for driving as much as I do. I'm sure if that's what the car came with I would get used to it. I prefer comfort and function vs bragging i have the shortest shifter. Just something to keep in mind. Also I haven't sat in a 15 but the shifter position is low compared to say a Supra where you also want a shortened height because the center console is higher
  6. #19
    Feb 2013
    My wife ended up getting a base model without the short shifter. My wife test drove one with and without the short shifter and mentioned the one without the short shifter being a little smoother to operate while being a little longer than the short shifter version.
    I compared the shifters, albeit without driving them. It would seem I could live with either just fine.
    Was able to test out a new Miata shifter as well...that one was really nice.
  7. #20
    Apr 2014
    Pennsylvania
    First off, Sorry to thread jack, but since this is already about the short throw, I thought I'd ask.
    Does anyone have the technical install guide for the short throw shifter on a 15'?
    I bought a 2015 WRX Limited and it didn't have a short throw, so I ordered one when I paid for the car. The dealer installed it and 10 days later I have massive amounts of slop left/right and can only get into 3rd and 5th (No reverse or 1st). Note: Slop might not be the right word because it feels like it's disconnected laterally.
    I'm wondering if someone has the install manual so I can see what part they probably didn't re-install right.
  8. #21
    Registered User RichD514's Avatar
    Jun 2012
    Long Island, New York, United States
    Quote Originally Posted by sachem87184 View Post
    Don't be afraid to start your own thread, you tend to get better info that way. Someone with the installation guide (if it even comes with one) might pass by this thread, but would check into one titled "looking for '15 STS installation guide".
    I'd have the dealer who installed it deal with it.
  9. #22
    Apr 2014
    Pennsylvania
    Quote Originally Posted by RichD514 View Post
    Thanks for the advice, I'll start up a thread of my own if I dont find the information in the thread you mentioned.
    As of right now the dealership is dealing with it, but I'm the type of person who trys to find out how things operate so I have a better understanding when approaching the situation at hand.
  10. #23
    May 2014
    Hampden Maine
    I just put 4K on my 15WRXLTD with the stock shifter. It was okay. I tried a demo with a STS, I definitely like the throws from 3 to 4 to 5 much better. I drove a VW bus years ago where there was over 6" of slop in the shifts, and got used to it, so this is not a deal breaker. I am glad I went with the stock first, but Monday the STS goes in. Am sure I will adapt to it just fine. I had Saabs previously, and the linkage felt like they used rubber bands. Will report on it after a while
  11. #24
    May 2014
    Hampden Maine
    My 15 LTD WRB had the stock shifter. After 4K miles, I decided I would splurge for the STS. There is a noticeable difference, also not as notchy. Big difference is from 2nd to 3rd, then 4 to 5. I would've saved some money if I had it installed at port. Dealer did a good job, road tested it, so I am pleased. I don't know if a newbie to shifting would notice it however.
  12. #25
    Registered User anxiouz's Avatar
    Aug 2010
    So Cal
    FWIW I did the Kartboy sts kit on my 11 WRX. I also did the shifter bushings. All parts plus local shop install came to around $350 I believe.
    It was awesome. So don't holdup your car for the STI/oem unit. When I ordered my car that was unavailable which is why I got the car and then went aftermarket.
    Steve // 2010 Cadillac CTS-V // 2011 WRX hatchback (SOLD)
  13. #26
    May 2014
    Hampden Maine
    I just changed standard shifter to the std on my 2015 ltd. Cost was 95 for labor and 300 for parts from dealer. The factory std is not notchy like the standard one, and I feel the 2 to3 and 4 to 5 is much crisper. But its totally subjective. Maybe my being $400 poorer make the shifter feel better? Driving manual trans for years might make me more critical.. don't know. I definitely wouldn't hold out to find a std on the lot. can always add.
  14. #27
    Jun 2012
    Quote Originally Posted by guzziman View Post
    I try to avoid std's at all costs..but hey..to each his own, as they say
  15. #28
    Registered User hefdukes23's Avatar
    May 2015
    I guess my question is, does the STi STS shorten the shift rod any? Or is it exactly the same height as stock? I just picked up my new '15LMTD with the STS in it on Saturday and don't have the point of reference in any that DONT have the STS.
  16. #29
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by hefdukes23 View Post
    Height should be similar -- throw is much shorter.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  17. #30
    May 2015
    Thank you, sir!
