2014 WRX SPT STS Upgrade to Kartboy Question
Results 1 to 8 of 8
This is a discussion on 2014 WRX SPT STS Upgrade to Kartboy Question within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Hey Guys, I currently have the SPT STS from the factory. I want to upgrade to the Kartboy SS. I ...
    Nov 2012
    Ft. Lauderdale
    Hey Guys,
    I currently have the SPT STS from the factory. I want to upgrade to the Kartboy SS. I have read that I need the 97-01 shifter as the factory STS is narrower then the OEM.
    Does anyone have any insight? also, do you recommend the bushing upgrade?
    Thanks!
    Jan 2012
    New Jersey
    CFLip2x 2012 WRB WRX Build
    May 2010
    Pittsburgh, PA
    I'm not sure about the 5MT, but in the 6MT, the factory STS is all in the linkage under the main lever... Put another way, you can (and I do) use both the factory STS and a Kartboy lever. I would suggest calling a good vendor (TurninConcepts) and asking them to make sure you get the correct sized bushings/lever.
    2011 STi Build Log
    Palmyra, NJ
    Quote Originally Posted by TREX954 View Post
    Hey Guys,
    Thanks!
    I have a 2012 WRX with short shifter...and proceeded to do a Kartboy short shifter on top of it. I just ordered from RallySportDirect, what would fit a 2012 WRX and it would be fine (so much better than the SPT short shifter only).
    2014 won't be any different.
    Mar 2014
    Westchester, NY
    Not to jack the thread, but does the same apply for upgraded bushings? I assume the front bushing doesn't matter, but when you upgrade the shifter to the factory STS, you get a rear bushing, but I would imagine a crappy one? I'm looking to do Cobb bushings, as well as possibly a STS on top of the factory STS as well, the same as the OP was talking about.
    2014 Subaru WRX Limited Sedan in Crystal Black Silica
    Mods - STi Short Throw Shifter w/ Cobb Bushings,Totsubo Front License Plate Mount
    2015 Dodge Durango Citadel in Bright White
    Retired: 2002 Subaru Impreza 2.5 RS 5-speed, 2005 Acura RSX Type-S 6-speed, 2010 Honda Accord Couple EX-L V6 6-speed,2009 Acura RDX w/ Tech Package in Grigio Metallic.
    Palmyra, NJ
    I'm not sure what bushings are offered, but I'd just stick with aftermarket such as Kartboy, Cobb, Perrin etc anyway over SPT stuff. But as long as its Urethane, it's better than the stock rubber ones.
    Mar 2014
    Westchester, NY
    yea mine happened to be a factory installed factory STS and bushing, so I didn't know if I should leave the rear bushing and just do front. seems like just do both and get rid of the stock STS one they gave me.
    Jan 2012
    New Jersey
    Quote Originally Posted by XxSullyxX View Post
    If your going to take the time to change one change the other search for comparison of the bushings and you should find a pic of the spt rear and other aftermarket rear bushings very noticeable difference
    Sent from my SCH-I545 using Tapatalk
