Transmission overfilled?
Results 1 to 6 of 6
This is a discussion on Transmission overfilled? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I drained and filled my 06 WRX 5MT transmission tonight. The liquid level on the dipstick is on the F ...
    Jun 2012
    PA
    I drained and filled my 06 WRX 5MT transmission tonight. The liquid level on the dipstick is on the F instead of the circle in front of the F. Is this considered overfilled?
    Jun 2012
    PA
    bump
    Jun 2012
    PA
    Anyone?
  5. #4
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    I did the same thing when I last replaced my transmission fluid. I cannot remember if I tried pulling some excess off with a syringe, though. In the end I may have had a bit too much oil anyway. I checked the dipstick after a drive to see if the oil was frothy (it wasn't appreciably frothy after a re-insertion of the stick for a proper level check) and things have been fine since.
    David - '05 WRX
  6. #5
    It's a vented gearbox. I was taught this here. I'd not worry. Since there is no pump and lube is circulated by glorified splashing anyway I don't know if there would ever be frothing.
    Les jeux sont faits.
  7. #6
    Feb 2014
    PNW -WA STATE - rainy side
    Slight overfill is fine.
