bolt popped?
Results 1 to 13 of 13
This is a discussion on bolt popped? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; i just installed my transmission mount today and when i was tightening down the 17mm bolt i heard a pop ...
    Nov 2012
    CT
    bolt popped?
    i just installed my transmission mount today and when i was tightening down the 17mm bolt i heard a pop and now it won't tighten or loosen.
    can i just ignore it or do i need to replace?
    Work In Progress GRBOXR's Avatar
    Jan 2014
    Long Island, NY
    When you say it wont tighten or loosen, is the bolt spinning in place or is it stuck (doesn't rotate either direction)?
    Nov 2012
    CT
    the bolt spins
    it takes a little effort to make it spin
    i can't do it by hand.
    the crossmember is still tight onto the frame
    Jan 2014
    Long Island, NY
    If I am not mistaken I believe the bolt you are referring to gets threaded to a welded nut. Sounds like the welds on that nut let go thus the spinning but not tightening nor loosening.
    I'm assuming the bolt was almost fully tightened when you heard the "pop" which would also explain why its difficult to spin the bolt. It may be tight at the moment, but you are at risk of it backing out over time. I would look into getting back there and tack welding the nut back on or finding another means of fully securing that bolt on.
    Nov 2012
    CT
    ok i'm not too sure how i'm gonna be able to do that *tack welding the nut* what other means are out there for me?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by jling0311 View Post
    You COULD use chemical weld, but I would seriously just have someone quickly tack-weld it.
    Did you use proper torque when tightening the nut?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Nov 2012
    CT
    it literraly popped close to 75ft-lb. how do even get access to that area to tack/chemical?
    Jan 2014
    Long Island, NY
    Unfortunately by making a hole through the inside of the car. If you can't/don't want to tack-weld the nut back on you could probably use a socket on the nut while you tighten the bolt, which if that's the route you choose to go I would use a lock washer. I recommend tack-welding it back on however.
    Registered User subypete's Avatar
    Jan 2008
    Forsyth, IL
    Came here from your other thread.
    You said you were going to use anti-seize on your bolts... did you use anti-seize on the bolt that broke? If so, I'm guessing your bolt broke because it was over-torqued. Anti-seize, as the name indicate, prevents seizing... typically used with stainless steel hardware. However, it also acts as a lubricant. According to various anti-seize manufacturer specifications, bolt torque should be reduced by 15-30% when using anti-seize on a bolted joint that calls out a "dry" torque.
    So if whatever manual you were using to you to torque to 75 ft-lb, then you likely should have used a lower value - something like 53 ft-lb.
    2013 Nissan Leaf SL - Extra Leafy
    2002 OBP WRX - Stage II - "Black Betty" - SOLD
    1987 Subaru GL Wagon - Stock - "Mr. Ratburn" - SOLD
    Jan 2014
    Long Island, NY
    Quote Originally Posted by subypete View Post
    I don't think the bolt is broken, but the nut broke off as mentioned earlier in the thread. Even if the torque on the bolt should be reduced due to the use of anti-seize, 75ft-lbs would of been fine since the factory torque spec calls out for 103.3ft-lbs (27% less) 1610.pdf
    Jan 2008
    Forsyth, IL
    Quote Originally Posted by WRX309 View Post
    You are absolutely right. On occasion, I am guilty of not reading the entire thread... even very short ones.
    Nov 2012
    CT
    update
    i didn't not use any anti seize on the bolts
    i had 2 separate body shops look at it and for now it's ok because the bolt is torqued down enough to hold *bolt unwilling to spin by hand* and i was told to keep an eye on it. they're looking to charge about 200-300 to fix this. is that a decent price or am i getting shafted?
    thank you guys for all the advice.
    Apr 2013
    FSM is wrong. The torque spec is actually 75 lbft.
