Awd driving technique for preservation - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on Awd driving technique for preservation within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Rev to 6000 RPM. Dump clutch. Run 11s....
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User Sinjhin's Avatar
    Feb 2014
    Urbana, Illinois, United States
    Yeah, as hard as it is on the system... a proper clutch drop in an AWD is Whasume Saose...
    I guess the inverse of my argument is go crazy til something breaks, replace broken part with something that won't break... make more awesome. Rinse. Repeat.
    2014 WRX Hatch
    Feb 2014
    Yea shinji thanks. I wasn't talking about launching/redlining, I don't do that at all really. I was talking about normal cruise speeds. I usually go to 3k-shift-drop clutch, and in 2nd sometimes ill hear a chk-chk in the drivetrain. Is that normal?? If I let the clutch out fast but gradually I won't hear it, but is that worse? Does that burn the clutch?? I'm really asking what's the less of the two evils?? I get what your saying tho, thanks for clearing that up
  6. #19
    Jan 2012
    Philly Area
    Quote Originally Posted by Matt troise View Post
    If you drop the clutch that is a sudden shock on the system, hence the clunk. If you slip it a bit (what you referred to as letting it out fast but gradually) the strain is no longer a sudden shock where everything all of a sudden bangs together in gear, but instead is kinda slipped into gear. That will wear your clutch, but that's what it's for. The clutch and some associated parts are wear items, you will have to replace them eventually. The sudden shock of dropping the clutch, that may cause wear/damage to parts that are not things you want to be replacing frequently or at all. Also increases the chance for something to actually break on the spot, instead of gradually wear down.
    Try to avoid the clunk, you'll get a better feel for it the longer you drive the car.
    - Will
  7. #20
    Feb 2014
    I am new to these cars, so this is somewhat guesswork. That is most likely your rear diff gears banging together. It is not that bad for the car, and it is normal if you pop the clutch while shifting. Mine does it too. It is not good for the car though and it is not how you should be driving it on a daily basis.
    That is exactly what you should be doing. It is not burning the clutch as long as the RPMs make a smooth transition from the RPMs in one gear to the next. If you shift at 3k RPMs, the needle should go from 3k directly down to where they should be at for the next gear. If they go above 3k RPMs when you shift, or sit at 3k or so while you are letting out the clutch then you might be slipping the clutch a bit.
    My suggestion would be to look at some of Mike's (SmurfinWRX on Youtube) video on shifting and just listen to what his shifts sound like then try to replicate. I would give other examples of good shifters on youtube and links... but Youtube is down right now.
    2014 WRX Hatch
  8. #21
    Registered User Stunna02's Avatar
    Aug 2013
    Seattle, WA
    I've got 12k miles on my car and i still sometimes lurches a little when I upshift...
    I mean I let the RPM's go down, and it doesn't make any noises, it's just not as smooth as when I had a honda when I was younger
  9. #22
    Feb 2014
    Ok gotcha, yea that's what I normally do fast but smoothly and rpms drop to 2k. I only got that chk-chk sound once or twice when I would let the clutch pop out. Ok good thanks
  10. #23
    Registered User rgrafton's Avatar
    Jan 2014
    never understood why everyone feels that these cars are hard to drive. Maybe I'm just a natural. lol. even the first time I test drove it, I had no issues whatsoever.
  11. #24
    Feb 2014
    Quote Originally Posted by rgrafton View Post
    They are just a little different than FR/FF. Most people have experience with non awd vehicles
  12. #25
    Registered User poi88's Avatar
    Feb 2013
    Long Island, NY
    Quote Originally Posted by Stunna02 View Post
    Yeah it's nowhere near as smooth as my last Mitsubishi either
  13. #26
    Registered User RichD514's Avatar
    Jun 2012
    Long Island, New York, United States
    I wouldn't say its hard to drive.. Just a little more finicky than most other cars.
  14. #27
    Feb 2014
    Mine will only lurch if I don't give it enough gas. But mine is still brand new so. My last car was a mustang gt and my wrx is light years beyond a better performing car
