Clutch
Results 1 to 10 of 10
This is a discussion on Clutch within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I know asked this over and over can't make my mind up act or competition clutch stage 2 or excedy ...
    Registered User Z31_2011's Avatar
    Oct 2013
    Monticello, Kentucky, United States
    Clutch
    I know asked this over and over can't make my mind up act or competition clutch stage 2 or excedy stage 1 hd the act is stage one and about same torque as the competion clutch stage 2 really need help so I can order it and be on the way do plain on doing other mods next yr and the car is daily driven
    Clutch is rated to power (torque) output...where will your car fall?
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
    Oct 2013
    Right now car has 300 hp stage 1 now but next yr be adding more and clutch is slipping now so that's why i need answer the labor is high I need a clutch can stand extra power and last while
  5. #4
    Quote Originally Posted by Z31_2011
    You didn't answer my original question, so no one can answer yours...
  6. #5
    Oct 2013
    The car is 2011 wrx impreza 5 speed not sure if how much torque it has but know the hp of now is 300 stage 1
  7. #6
    As I said, a clutch is based on torque capacity, so without knowing what we're looking at, we can't help you...
    If you "know" the hp, you should "know" the torque.
  8. #7
    Oct 2013
    Just used a cobb ap so can't remeber torque but act stage 1 torque cap is about same as comp clutch stage 2
  9. #8
    Where do you see yourself going with the car? If you don't ever plan on going beyond a pump gas tune on the stock turbo, you should stick to a stock (or OE replacement) clutch.
  10. #9
    Oct 2013
    Next yr plain on adding turbo upgrade so right now I can't tell the torque bc I can't pull hard the clutch is about gone
  11. #10
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    I already mentioned this, but based on where you are at right now (stage 1 tp tune), you are no where near the torque that would require anything stronger than an OEM clutch. I honestly think you would regret going with a really heavy clutch at this point, as it would take away from your daily driving experience. If you are planning a big build later down the road, I would just put in a stronger clutch when you 'need it. As you know a large component of the cost will be labor, unless you do the work yourself. When you are doing your turbo replacement (and all the other supporting parts), I would do the clutch to match the power needs then. Your tuner will be able to give you an idea of the torque you will be making based on the mods he will be tuning your car for.
    However, you seem to be very intent on getting a stage 2 clutch, so if that is truly what you want to do then go for it
