transmission overfill question
Results 1 to 6 of 6
This is a discussion on transmission overfill question within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Hi folks, I overfilled my 2011 wrx tranny by about 1" past dipstick F mark. Interestingly, I only added 3.6qt ...
    Dec 2013
    Unhappy transmission overfill question
    Hi folks,
    I overfilled my 2011 wrx tranny by about 1" past dipstick F mark. Interestingly, I only added 3.6qt of extra S. I took the car for a short drive, and noticed the fluid is full of tiny bubbles. What is the best way to get the extra fluid out? How much would a shop charge to correct this? Will my transmission blow seals and leak at the axles if I don't remove extra fluid?
    In my freak out attempt to fix, I used an old hose (I typically use this hose to drain engine oil) to try and syphon some fluid out. I wiped the outside of the hose clean and stuck it down the fill pipe, but the inside had remnants of used 5w30. Assuming a few ml's of this leaked back into my transmission, is this a big deal? I couldnt actually get any fluid to come up, so this method did not work for me.
    Thank you
    If the gearbox has not changed it is vented and does not use a pump. If so -- but only if so -- I do not see a problem.
    - Al Stewart
    Dec 2013
    I ended up taking 0.6qt out, now I'm at the top of F. This means total fluid added is around 3.1qt.
    Do you see any problems arising from me using a hose that had old 5w30 oil inside to do the syphoning?
  5. #4
    If it were my car I would not worry. You're talking about less than 1% by volume.
    I have seldom been able to add more than just over 3 qt of gear oil. Capacity is higher but I think the viscosity plus relatively low temperatures makes it hard to do a full drain.
    Anyway I'd not be worried.
    - Al Stewart
  6. #5
    Dec 2013
    thank you
  7. #6
    You're welcome. The link in my signature has lots of info if you want to look through how-to threads etc on a slow day.
    - Al Stewart
