Wheel shudder when turning- 200 WRX STi
Results 1 to 9 of 9
This is a discussion on Wheel shudder when turning- 200 WRX STi within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I am having an issue curently on my 05 STi and I am searching for the solution. I have slow ...
    Apr 2013
    I am having an issue curently on my 05 STi and I am searching for the solution. I have slow speed wheel shudder when turning the wheel left or right that transmits thru the steering wheel. I don't hear any associated whine or metal on metal or clicking like it a CV or anyhting else, not air in power sterring resevoir etc. The steering wheel "shudders" and you hear a vibration (not metalic or clunking) noise somewhere under the car?
    Another slightly scary thing happened this morning when I was on a off ramp (cloverleaf) and decelerating with light braking, the car suddenly (only for a fraction of a second) lurched to the left towards a reatining wall and I almost %^&* my pants.
    I did read on one similar thread about the "tone rings and ABS sensors" since this information is fed to the center diff and it could be receiving "bad data" concerning the wheel speeds?
    Ideas?
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Check tire wear, NOW! I bet your alignment is off.
    Apr 2013
    Quote Originally Posted by Ingo View Post
    I just installed 4 BRAND new Blizzaks last week and cat doesn't pull. Other ideas??
    Registered User atranz's Avatar
    Aug 2012
    houston, tx
    Knuckle bearing?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Apr 2013
    Quote Originally Posted by atranz View Post
    Knuckle bearing?
    Would that be plausible with only having 55k miles on the car? How do you check it?
    Thanks
    Aug 2012
    houston, tx
    Jack up the car and see if you have play in the wheel. I always hold the rim/tire with 2 hands and rock it back and forth. In its early stages you can hear a slight grind then it gets louder. If its the front under heavy braking it'll pulsate.
    Check you axle nut and torque them to spec. Sorry I don't know the specs.
    Others please chime in if I'm wrong.
    Apr 2013
    Will do, THANKS
    Palmyra, NJ
    Quote Originally Posted by createaneutron View Post
    Thanks
    Only 55k yeah, but it is a 10 year old car now.
    Apr 2013
    An update to my problem and the discovered solution. It turned out to be the power steering fluid needing to be flushed and changed. After this was done, the shutter disappeared! I couldn't figure it out, but a local shop nailed it! I was thinking the worst and it turned out to be a fairly inexpensive solution
