Help me figure out what happened? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Help me figure out what happened? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Anyone else got thoughts on whether trans might still good and it is just a piece of clutch floating around?...
    Jul 2013
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Na, tranny is a goner..., sorry, wouldn't want to raise false hope. The noise you're getting when finally in 3rd, that's bad. Like it was said before, drain the transmission, see what comes out. You find pieces - you KNOW what's up. And you're s'posed to change tranny oil from time to time anyways, so that couldn't be wrong to do.
    Mar 2012
    Na, tranny is a goner, sorry - but I would not want to raise false hope. The noise you're getting when finally in 3rd is a really bad indication. Go ahead and drain the tranny, like it was already suggested. If and when you find pieces you KNOW what's up. And tranny fluid is s'posed to be changed sometimes anyways, so no loss doing this.
    If it was the clutch you'd get the same noises at same engine speed, independent on what gear, only dependent on rpm's.
  5. #19
    Jul 2013
    Ah well. worth a shot.
