act 6 puck clutch with stock pressure plate
Results 1 to 12 of 12
This is a discussion on act 6 puck clutch with stock pressure plate within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; How will the ACT 6 puck clutch work the stock pressure plate on a 09 wrx. And how hard is ...
    Registered User jballard388's Avatar
    Sep 2013
    SC
    How will the ACT 6 puck clutch work the stock pressure plate on a 09 wrx. And how hard is the install because in alaska 125 a hour for labor is crazy.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    That's too much clutch. Consider something more reasonable, or your 5spd will end up in a junkyard.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Sep 2013
    SC
    what would you recomend. My last car was a mustang and i am still used to just picking out good bolt ons and stuff that could handle lots of torque.
  5. #4
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    I would probably just keep your stock clutch...no need to change it unless its slipping!
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  6. #5
    Sep 2013
    SC
    I am just wanting to beef up the tranny without having to do a swap. I plan on adding some hp eventually and I want to work on the weak point first.
  7. #6
            MainFrame's Avatar
    Austin, TX
    The 6 puck is notoriously harsh on engagement.. I mean really bad. Unless you only use the car for racing (ie. trailer it to the track), then you're going to want a full face disk.
  8. #7
    Sep 2013
    SC
    yea im just a noob with the whole awd and subaru thing. And all I know is mustangs. miss having a stock transmission that could handle 400 plbs of torque then some, but dont miss the car.
  9. #8
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by jballard388 View Post
    Stock clutch for anything under about 330whp.
    Installing a clutch with a greater clamping force will make your transmission MORE likely to fail, not the other way around. If you want to increase the strength of the transmission you need to either replace the gear set with something like PPG gears, or perform a six speed swap. But like I said, unless you're planning on significantly increasing power (which would require an engine build to stay semi reliable), I wouldn't mess with the clutch.
    I would consider the weak point to be the suspension and brakes. Also pistons, and the 5 speed transmission design.
  10. #9
    Sep 2013
    SC
    cool appreciate the advice. as far as HP im just wanting intake, tune, full exhaust, better intercooler, and synapse diverter valve.
  11. #10
    Jan 2009
    Central PA
    Stay away from light weight flywheels too. They are a pain in the ass.
    Subaru Guide
  12. #11
    Sep 2013
    SC
    yea Im moving to alaska and alot of people have subarus up there so hopefully I can find somebody with a pretty decently modded wrx to help me.
  13. #12
            MainFrame's Avatar
    Austin, TX
    Stock clutch and transmission should be just fine for that, unless you're really trying to break something.
    As long as the diverter valve is recirculating you should be fine. Personally, I would add a 3-port EBCS to that list. And I think you'll want a new fuel pump and injectors if you want to push it.
