Squeak after clutch change.
Results 1 to 3 of 3
This is a discussion on Squeak after clutch change. within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Noob here. Apologies in advance. Did some searching but didn't find anything to help clarify what's going on exactly... 2011 ...
    Registered User rockchalkLT's Avatar
    Mar 2013
    Kansas
    Question Squeak after clutch change.
    2011 WRX hatch ~50,000mi. Just got a throw-out bearing warrantied by Subaru and purchased a new clutch while they had the tranny out to save on $$ later down the road. Anyway, it's my understanding that for a new clutch you should be very gentle with it for the first 500 or so miles to break it in. I've put about 70 on it so far since yesterday but I've noticeed a distinctive squeaking sound coming from the engine bay when I get going out of 1st and every time I go over small bumps and imperfections on the road. If the road isn't perfectly smooth it's squeaking/chattering away.
    It's really annoying and again, I understand some of this is normal(?) with a new clutch since it hasn't been broken in yet but should it really be making loud squeaking sounds while going over every single little bump in the road? I've tested it while in neutral and the sounds goes away.
    Take it back and have them fix it. I bet it's something physical like a mount or something rather than the clutch but in any case they get to sort it out.
    Mar 2013
    Kansas
    Fixed. Took it in this morning, the tech forgotten to tighten a bolt
